View Poll Results: From what I said, which would you choose?
Vishnu Stg1+
55
39.29%
Vishnu Stg1+ (With Buschur Exhaust)
6.43%
Buschur Stg 3
16
11.43%
Buschur Stg 4
55
39.29%
I think both will make your car to prone to problems.
3.57%
Voters: 140. You may not vote on this poll
Vishnu Stg1+ vs Buschur Stg 3/4
Originally Posted by jfh
I believe that others have found that DB's mod path offers similar results and reliability.
At the end of the day I would opt for the tuner that is most accessible to me for custom tuning, whether it means going to them or them coming to a shop near me. Generic maps and/or ECU reflashes are never as good as a custom tune.
Originally Posted by shiv@vishnu
Our standard or signiture Stg 1+ can be upgraded (as far as power output goes) by adding a test-pipe (instead of the high flow cat), a 10.5 housing (or TME turbo), or a *good* upgraded FMIC with proper end tank design. That's pretty much it as far as how far you can go with the stock turbo while retaining good reliability. Of course, i think the best add-on for the Stg 1+ is going for the XEDE option (instead of the XFlash) and having a race gas map loaded into the secondary map bank. An safe extra 30-40bhp at the flip of a switch
Not to mention the soon-to-be-released road dyno software and few other nifty tuning aids (all built in to the XEDE software) for those who either want to tinker themselves or want to make sure that we did our job right with the baseline mapping.
Hope that helps,
Shiv
Not to mention the soon-to-be-released road dyno software and few other nifty tuning aids (all built in to the XEDE software) for those who either want to tinker themselves or want to make sure that we did our job right with the baseline mapping.Hope that helps,
Shiv
Originally Posted by VTECH8TR
Ditto,
I have a Buschur stage 4 car and i couldn't be happier. I have spent some money in all types of parts while swapping out. I tried them all Injen, HKS, Dejon, etc.. At the end i went with Buschur parts. My engine bay looks beautiful and performs like its on steroids
IE EVO,
Alky and Methanol injection are not in our Stages 1-4 or any of our staged upgrade packages. This is an independent choice for some guys who want high boost and to run pump gas too. Run the right alky, do periodical checks on the pump pressure and I see no problems or safety issues with the kits.
Florida, we have no guys down there that we recommend for tuning and such. Our flash works extremely well through the mail for our stages. The reason they do is the consistancy of our parts and the packages. Doing a flash through the mail when you have a wide variety of parts on the car from many different companies makes it harder to get the tune right on. With our Stages we have a flash for what WE build and OUR combination, makes it easy to do the tune and get it right.
David Buschur
www.buschurracing.com
David Buschur
Originally Posted by ronitlancer
Who put your parts in and did your tuning? I'm in florida aswell.
If you go the Exact Buschur path, we can send him your ECU to be flashed but only for HIS parts.
I remember pm'ing you a couple times. I live in Pasco down the street from you.
ronitlancer,
I am seriously hoping you are a girl, am I correct? If I am correct, what are the chances that is an actual picture of YOU in your signature box?
David Buschur
David Buschur
Originally Posted by davidbuschur
ronitlancer,
David Buschur
David Buschur
I do my own work as well as work on 4 other local evos. If you need help installing any mods on your evo send me a pm for my cell #. I prefer Buschur parts though. My tuning was done out of state cuz i have an AEM.
Ya i just rememberd before i saw that you said it. We did talk before.
ronitlancer,
David Buschur
David Buschur
Anyway I'm not. and no that girl is Vida Guerra. She is a model.
She recently got her cell phone hacked too. And she has nude photos running all around the net
I voted for the exact setup I have, which doesn't seem to be very popular... The Vishnu Stage 1+ with the Buschur exhaust.
For me, this has been an absolutely flawless setup for 15 months now. The drivetrain has had exactly 1 problem in 15 months, when I blew the upper I/C hose right off the throttle body under boost (my fault for not clamping it tight enough). That took me exactly 3 minutes to fix.
I'm also with jfh, access to an experienced tuner is very very nice to have. Shiv spent close to two hours on my car (30 dyno pulls), first sorting out boost issues and then giving me both a street fuel map and a race fuel map. I have not had to touch either map in 15 months; they work great.
I'm sure that Buschur can provide a great solution as well; but Vishnu did a wonderful job for me. Shiv didn't even make any snide remarks about seeing the Buschur exhaust on my car...
