View Poll Results: From what I said, which would you choose?
Vishnu Stg1+
55
39.29%
Vishnu Stg1+ (With Buschur Exhaust)
6.43%
Buschur Stg 3
16
11.43%
Buschur Stg 4
55
39.29%
I think both will make your car to prone to problems.
3.57%
Voters: 140. You may not vote on this poll
Vishnu Stg1+ vs Buschur Stg 3/4
Originally Posted by ronitlancer
Cool, that helps a little bit, also would you ever be around the area for you to do any tuning? I would like to have you do it
The idea of a baseline reflash (or baseline XEDE map) being optiminal for any and all similarly modifed cars is untrue. If Mr. Buschur actually took the effort to travel and tune a fair number of customer cars himself, he might see that being the case. This has certainly been proven time and time again at all our dyno days. Not just with our products but with other 3rd party reflashes as well. FWIW, we map, on average, 30-40 EVOs a month. Or as many as 100-120 a month during dyno day season. This is what it takes to make a good baseline file. Not typing on internet forums and insulting other tuners. And even then, custom tuning can yield an additional 10-20whp depending on car and set-up.
Regards,
shiv
Originally Posted by jbrennen
I voted for the exact setup I have, which doesn't seem to be very popular... The Vishnu Stage 1+ with the Buschur exhaust.
For me, this has been an absolutely flawless setup for 15 months now. The drivetrain has had exactly 1 problem in 15 months, when I blew the upper I/C hose right off the throttle body under boost (my fault for not clamping it tight enough). That took me exactly 3 minutes to fix.
I'm also with jfh, access to an experienced tuner is very very nice to have. Shiv spent close to two hours on my car (30 dyno pulls), first sorting out boost issues and then giving me both a street fuel map and a race fuel map. I have not had to touch either map in 15 months; they work great.
I'm sure that Buschur can provide a great solution as well; but Vishnu did a wonderful job for me. Shiv didn't even make any snide remarks about seeing the Buschur exhaust on my car...
Shiv,
Do you ever go down to dyno4mance? I could meet you there, if I end up going with your package.
Do the majority of you guys think I should just get most of the parts seperate and install myself? Then get the Xede / Buschurs flash depending on whicever path I take. Then just get the tuning done? Or should I just go all the way adn go straight to Stg 4 or Vsh Stg1+
The bottom line is whatever you do, if you go with a reputable company and tuner, you'll be very happy, and your car will be SIGNIFICANTLY faster than stock, as well as most cars on the road
Originally Posted by davidbuschur
Cam gears suck, I won't use or recommend them to anyone, well maybe an enemy.
http://www.buschurracing.com/cgi-bin....cgi?25X376545
From your website:
"HKS Adjustable Cam Gears allow fine tuning of the camshaft timing to maximize engine performance and tailor power characteristics for various driving conditions. Either with OEM or HKS Camshafts, adjustments can be made to tune an engine's power band to the optimum RPM range for a particular application. HKS Cam Gears are made completely of anodized aluminum except for applications with timing chains which utilize an aluminum slide with steel teeth. NOTE: Mention seeing this and recieve free shipping on this item."
Regards,
shiv
Originally Posted by shiv@vishnu
So I suppose those browsing your website are considered enemies?
From your website:
Regards,
shiv
From your website:
Regards,
shiv
Stop battling. You two are ovbiously both very good companies. Theres no point to putting eachother down. You both have 100+ people on this forum with your parts. No need to put eachother down.
It will probably one of the fastest cars in my area. Besides the 5 or 6 STI's that I see, also my neighbors Lamborgini.
But I can beat my moms SL500!
We get a lot of Floridians when we do our GA dyno tuning events in Calhoun Georgia at Dyno4mance (www.dyno4mance.com). It's a bit of a drive but most seem to think it is worthwhile. So far, I think I've personally tuned nearly 100 cars in that neck of the woods. I'm sure a good portion of those were from Fl (as well as Tenn. and other neighboring states.) Andrew at Dyno4mance has done a lot of EVO tuning work with the XEDE as well so he can certainly help you out as well.
Regards,
shiv
Regards,
shiv
Keith
PS: I refuse to edit anything in this thread due to my personal involvment... other mods will have to edit out any crap talking posts.
From your website:
Regards,
shiv
From your website:
Regards,
shiv
PS - that was a biatch move
From your website:
Regards,
shiv
From your website:
Regards,
shiv
Why dont you quit knit picking and trying to start sh*t and get back on topic. Man you get on my nerves.
Jarrod
Buschur Racing Inc.
From your website:
Regards,
shiv
From your website:
Regards,
shiv
DAAAAAYYYYYMMMMNNNN Someone just got OOOOWWWWNNNNNNEEEDDD.
Originally Posted by Jrod@Buschur
Actually Shiv I'm the one that put those up on our site as we are an HKS Pro-Dealer. It is at the customers own discretion on what they want to buy and it is our job to point them in the right direction of their build but if they chose to buy them we do have access to them. It is called ADVERTISING. But like David mentioned we do NOT recommend any type of cam gears wether it be AEM, HKS, Venom, etc. etc....
Jarrod
Buschur Racing Inc.
Jarrod
Buschur Racing Inc.
Originally Posted by mrmefodman
Thats it. Next shootout I am bringing a set of boxing gloves so you guys can just duke it out and get it over and then have a pee pee measuring contest and call it a day and live a happy tuning life.
Jarrod
Buschur Racing Inc.
Jarrod
Buschur Racing Inc.
Sorry if pointing out obvious inconsistencies in your claims/suggestions gets on your nerves. But you should be careful about sending such mixed signals to potential customers.
And Fourdoor-- I'm sure Dave has lots of experience with the 4663. A lot of experience with letting others tune them for him. First Tym (who left to start his own tuning company) and now Al. But his comments regarding baseline maps aren't true. And if he actually spent more time in the field, with more customer cars, he'd see that. Building fast shop cars is always fun and rewarding. But it's not quite the same as being hands-on with customer cars when it comes to refining ones tuning products.
Just my 2c,
shiv
