HKS 280's?!?!
Old May 7, 2005 | 04:30 PM
  #31
Mistasparkle's Avatar
hey ted what about just loading up a stage 1+ map off the vishnu webiste for the 280s? what else can i do if i cant get to a tuner asap?
Old May 7, 2005 | 04:32 PM
  #32
Ted B's Avatar
You can load a map from a similarly prepared car with 272s and be in the neighborhood with respect to tuning, but the increased overlap of the 280s may very well result in a leaner mixture where you least want it. In other words, you can drive around on it, but I'd be cautious about putting a good deal of boost through it until it's properly sorted.
Old May 7, 2005 | 04:36 PM
  #33
so running a max of 21 psi on pump 91 would be ok? can i get an afc and richen it out up top?
thanks for help
Old May 7, 2005 | 04:43 PM
  #34
Ted B's Avatar
If anything, the curve will probably leanest at max VE, which is at the torque peak.
Again, I wouldn't take risks by putting boost through it following *any* significant changes until I was able to tune it properly, so if you decide to crank 21 psi through it...and on 91 oct at that, you're taking your chances. You may be ok, but maybe not. Just my opinion.
SooReal
10
Aug 25, 2008 03:54 AM
MitsuJoe
21
Feb 9, 2007 12:51 AM
EvOcHaRgeR
15
Nov 6, 2006 10:23 PM
qbbraveheart
25
May 25, 2005 07:39 AM
Evo8Master
10
Jan 11, 2005 09:11 AM
