New Bolt in turbo... FP White Rabbit.
Old Jul 5, 2005 | 11:54 AM
  #826
dsm95hybrid's Avatar
Hey guys what do you think about this combo.
The White Rabbit Turbo, going into a Helix O2 Housing with Jet Hot Coated Headers from www.Phoenixturbo.com. So far I have TBE, CAMS, Fuel Pump, Cone Filter and Dynoflash. What kind of power will I be making after the White Rabbit upgrade.
__________________
It is a T3 manifold that will NOT work with the stock type tw-scroll turbo.
Old Jul 5, 2005 | 01:08 PM
  #827
pyrovice's Avatar
grrr I want mine now!!!!!!!!!!
Old Jul 5, 2005 | 05:56 PM
  #828
ELF's Avatar
ELF
Originally Posted by sleet
This thread is amazing, I just read through 53 pages and i wanna get one so badly! lol
i feel the same way
Old Jul 6, 2005 | 03:27 AM
  #829
EVO8LTW's Avatar
Well, jury's still out on my new White Rabbit. I installed it over the weekend and while I haven't attempted to start dialing in the tune, it doesn't make much difference over the stock turbo with the same tune, same boost (~20 psi) and the same pump gas. Numbers through the MAF are about the same and SOTP is about the same. Boost controller settings are the same to get the same level of boost. Slightly more lag at cruise RPMs, but nothing unacceptable. On-board e-dyno (Blitz Powermeter) shows maybe a 10 hp gain but not much more, whereas with cams there was a big jump on the e-dyno (like 25-30). Hopefully, I see more gain with tuning and find a big boost leak or other explanation for the lack of gain in performance. But any gains I see from here are not comparable to the stock turbo because now I'm tuning with a UTEC that I installed just before the WR.
Old Jul 6, 2005 | 04:45 AM
  #830
tcarretti's Avatar
EVO8LTW,
Did you honestly think that you were just going to bolt the turbo in and just realize an incredible power gain?!
The difference in flow from stock dictates that quite a bit of tuning is needed to realize the full potential of this unit. I'm sure that once you get it tuned you'll be singing a different "tune"!
Patience, grasshopper, when you can ****** this pebble from my hand, it will be time for you to go............
Tony
Old Jul 6, 2005 | 05:29 AM
  #831
ShapeGSX's Avatar
Take it to the track, turn up the boost, throw in some race gas, lean it out, add some timing and kick some ***!
Old Jul 6, 2005 | 06:51 AM
  #832
DizzyTT's Avatar
My dreams/wishes that my wife says NO! to.
White Rabbit Upgrade Dreams
Turbo $1,550
ARP Headstuds $100
Buschur FMIC $650.00
Fighters Garage LICP $145
FIC 650cc Injectors $339
Gaskets $20
Bolts $30
Buschur ported Throttlebody $300
Buschur ported Intake mani $75
Buschur Alcohol Injection $499
Dynoflash Tuning $300
Race Pipe $75
Wideband $500
Exedy Twin disk $1,300
Total $5883
Old Jul 6, 2005 | 10:03 AM
  #833
Erik@MIL.SPEC's Avatar
They (soon to be) wife said yes to my dreams. However, I don't want to add up what it's costing me.
Old Jul 6, 2005 | 10:04 AM
  #834
EVO8LTW's Avatar
Originally Posted by tcarretti
EVO8LTW,
Tony
I didn't expect a big jump in power without tuning, but I did expect a jump in the MAF flow numbers without tuning.
Old Jul 6, 2005 | 10:19 AM
  #835
tcarretti's Avatar
Is it just me, or doesn't the MAF come BEFORE the turbo? Correct me if I'm wrong here........
Tony
Old Jul 6, 2005 | 10:23 AM
  #836
Jon H's Avatar
But wouldn't you be sucking in more air?
Old Jul 6, 2005 | 10:24 AM
  #837
sleet's Avatar
Yes it comes before the turbo.
Old Jul 6, 2005 | 10:26 AM
  #838
DCSilvrEvo's Avatar
Tony
Tony your right!
  #839
tcarretti's Avatar
how would you be sucking more air? The turbo doesn't suck, it blows, and from what i understand, it blows into the throttle body, correct. The MAF simply meters incoming air from the intake, correct?
I'm not a real "motor" guy, but this all seems to make sense to me.
Think about it.......
Tony
Old Jul 6, 2005 | 10:29 AM
  #840
jj_008's Avatar
Tony
It has to suck in more air if it blows out more air.
