New Bolt in turbo... FP White Rabbit.
Old Jun 28, 2005 | 08:31 PM
  #676
nickracer9's Avatar
the manifold has 2 bolts and 2 studs that hold the turbo on. have you ever even pulled yours apart? nothing wrong with using 4 bolts instead of 2.
Old Jun 28, 2005 | 11:16 PM
  #677
AustinEVO's Avatar
Is there anyone that can give us a report on how this turbo feels on the street? I know there are a few running around out there by now, lets hear about it guys!!
Old Jun 29, 2005 | 02:30 AM
  #678
Zeus's Avatar
I'll give you a ride after the 9th... but for the most part, it feels like a stock turbo, surge free, up to about 4-4500rpm. Then more like a smaller GT30.
Old Jun 29, 2005 | 04:08 AM
  #679
tcarretti's Avatar
Ditto, keeping fingers crossed that my install goes as planned tomorrow and then in the afternoon on the dyno. Will be posting before and after numbers to try to give a good account of what this thing can do. Then have to drive it back to San Antonio from Austin so I should have a good feeling for it by then.
Keep you all posted.......
Tony
Old Jun 29, 2005 | 04:10 AM
  #680
VTECH8TR's Avatar
Originally Posted by Knyght
You can't be serious...
I've been running 4 bolts on every one of my big pile of garbage DSM's for years now and never had a problem. In fact those are about the ONLY part thats held up the abuse. As far as 'getting stuck and welded on" thats what they make antiseize for. How can you even be serious when the stock system has 2 bolts and 2 studs? I guess you would suggest all four studs then right?
Ditto,
I have been doing it this way for years to with NO problems. Knyght is correct it makes taking the manifold out alot easier going forward.
Old Jun 29, 2005 | 04:38 AM
  #681
Knyght's Avatar
Originally Posted by Az3ar
I am serious. Have you pushed your car a bit further than some road driving and racing? When you do please let me know.
I am suggesting to use studs not screws
I wouldn't use 'screws' either. Bolts rather
And yes I have, my talon is a daily driven and a weekend warrior at the strip. It sees traps speeds above 120 all day long, and I bet you I could go out right now and take out a bolt with nothing but a gear wrench. Dont push your previous problems with bolts when the clear and easier solution is available, and probably cheaper.
Fact is that the OE 'studs'/'nuts' and 'bolts' are made of the same material. They both rust. The casting of the exh housing rusts, it's inevitable. I've seen more studs get stripped than bolts snapping. Why do you think european corporations like BMW/Benz are using bolts instead of studs/nuts to attach their wheels to the hubs?
When it comes to torque specific applications such as converting to head studs instead of bolts, I would agree that they 'hold' more and stretch less. But we aren't taking about heads, and the turbo to manifold bolts dont need to be 80 foot pounds..
For 99.99% of the world (the .01% being you and some other "hyper extreme performance racers) bolts work just fine for turbo to mani, and it's ALOT easier to take the mani off.
Old Jun 29, 2005 | 05:53 AM
  #682
WrX Kila's Avatar
Originally Posted by TD05HR
yeah its a little pricey..but its the only one right now..so they can charge what they see fit...
plus , you gotta realize the compressor housing needs work too..not just bolt on the wheel and your done..
I have a GT3076 sitting here. I am considering getting one of these. Poeple say Lag is overrated its not! I am going to wait for dyno and road results and for the price to go down a couple of dollars before getting one.
Old Jun 29, 2005 | 08:11 AM
  #683
Az3ar's Avatar
I have pulled mine out about 10~15 times not joking. You are wrong the turbo turbine side has 4 studs and 4 nuts not screws. There are no screws between the manifold and the turbo all studs and nuts.
Old Jun 29, 2005 | 08:39 AM
  #684
Knyght's Avatar
Old Jun 29, 2005 | 09:54 AM
  #685
mitsuorder's Avatar
Let's all play nice guys. Ok so to those that are advocates of using heat treated bolts from the mani to the turbo, where do you get yours and what do you recommend as far as using to replace the 2 factory studs connecting the o2 housing to the turbo since their is a clearance issue when you attempt to use bolts there?
Old Jun 29, 2005 | 10:06 AM
  #686
Jorge T's Avatar
Hmmm my stock turbo has 2 bolts and 2 studs manifold to turbo, maybe the ATP is different.
Old Jun 29, 2005 | 10:07 AM
  #687
marksae's Avatar
Stick with the factory fasteners. You can replace the lower right stud on the o2 housing side of the turbine housing w/ a bolt, but I think Mitsu put a stud there since that hole is a thru hole which goes into the exhaust path. I put a stud back into that location.
As far as converting the manifold to turbine housing studs to bolts. Just order two more of the same bolts. This is assuming you're using the stock manifold.
Old Jun 29, 2005 | 10:09 AM
  #688
fareastkorean's Avatar
are these still available
Old Jun 29, 2005 | 10:10 AM
  #689
ForcedPerformance's Avatar
Hey guys,
The recomended hardware usage is as follows;
Turbine inlet - skip the studs and purchase two of the OEM bolts that are used. Upon installation use 4 of the OEM bolts instead of 2 studs and 2 bolts. It is easier to use 4 OEM bolts for R&R of the turbo. Studs complicate things, and the OEM bolts are the strongest high carbon nolts you will find anywhere.
Turbine outlet - Reuse the three OEM bolts and get two new studs so you don't have to bother taking the old studs out of the old housing. Removing old studs is a black art and most have not mastered it.
We have all the hardware you could need and usually ask during the order taking process if you want it, most people who have ordered the turbo have also ordered the hardware at the same time. Few have shipped without the option replacement hardware, but it would seem that those few are the ones taking in this thread
It is split, some guys laugh and say "hell no, I dont need no stinking hardware" and the rest say "yeah, I want that hardware" you can do the job either way, it is up to you.
Old Jun 29, 2005 | 10:13 AM
  #690
Zarathustra's Avatar
Heh I was one that didn't think about the optional hardware and man it was a nightmare trying to reuse all the stock stuff. Take Robert's advise and get it!
