New Bolt in turbo... FP White Rabbit.
Originally Posted by dryad001
So this is the right PN?
MN119784 (Manifold-Turbine) Stud
$7.45 a piece from the stealership.
Originally Posted by Tym Switzer
Thanks to all of those giving support and good feedback to the technical information in this thread.
If any of you guys who know how to install one of these could comment on my how-to request thread, I'd appreciate it. I've already put down the main steps that I think need to be done and am just looking to make sure I didn't miss anything significant:
Bolt-in turbo how-to thread
My WR arrived yesterday, so I'm anxious to install it. Thanks.
Originally Posted by Knyght
Why not use two new bolts instead of the studs? It would make life easier.
Sam
Originally Posted by EvoSam
Clearance issues prevent using bolts, especially on the O2 housing as you'd never be able to slip a bolt into a couple of the holes from above, they have to be studs from beneath. Plus, Mitsu uses small head nuts and bolts. If you were to try to find your own at the hardware store the head size would be much larger forcing another clearance issue. You can get regular old exhaust studs at the auto store, just use the factory nuts if you can.
Sam
Sam
Sam
Sam
