New Bolt in turbo... FP White Rabbit.
Originally Posted by Smogrunner
I know for a fact Atlvalet won't be able to drive up to Union City (NorCal) beforehand, as he is getting married on the 23rd of July. If the SoCal dyno day turns out to be on that same day, I'll probably meet up with him earlier and park his Evo at TT a few days before. Shiv, the best chance you have at having some "quiet time" tuning it would be if you showed up early on the Friday of the SMART seminar and tinkered with it then on Chris and Alfred's dyno.
Cheers,
Shiv
Here is the plan...for now...if the dyno day ends up being the 23rd/24th I'd drop my car off a week early at TT (16th or 17th). Since I'm getting a bunch of new stuff installed, TT can give my car the once over (check for boost leaks, maybe crush my JDM MR BOV with those 27 psi spikes, etc.) Then I would pick up the next weekend (30th).
Shiv, of course you can use my car as a learning tool. No problemo. I'll actually be up in San Fran next weekend (the 4th), but I won't have any parts on. It's all getting done over the next couple of weeks (thanks for the injectors Smoggie
New clutch and headstuds go on this week compliments of RRE. WR should be here tomorrow (some kind of train delay, so says UPS). And so on...
Anyway, regardless if I'm there or not, it's going to be a blast. Tom, I'll PM you my number if you or Shiv need to contact me.
).New clutch and headstuds go on this week compliments of RRE. WR should be here tomorrow (some kind of train delay, so says UPS). And so on...
Originally Posted by gnulooks
I was just looking at the fact that your going to run a MR BOV, for some reason I dont think that thing is going to hold 27 pounds of boost. I have read that its good for maybe 23, but nothing above that. You might have to do a thread search to find out because that BOV might compromise your entire tune...
Originally Posted by EvoSam
This has been discussed at length on these forums, a search should get you what you need. Do a search for threads started by me, I think someone told me the part numbers at some point. You want the thread titled "not so bolt on as they say" or something like that.
Zeus was right on the money about the oil return line gaskets. I tore mine at the oil pan and had to make a new one with gasket material, not the optimal fix but one that works. You should absolutely get the studs, nuts, and those gaskets. Some folks get the little crush washers too, I reused mine. I still contend that re-using the stock manifold to turbo and turbo to O2 housing gaskets are probably better than the ones that are included in the kits. Just my opinion.
Sam
Sam
Originally Posted by Soon2BEVO
I boost tested my MR BOV and it held 24psi! I dont know how much more its going to hold though. But it held 24 like a rock! Doesnt mean it wont leak at 25 though
Besides, this car will be more than enough for me to handle. I need to learn how to drive it better next. That's where all my future mod money will be going. That, and tires and brakepads
^^^^On 91 octane you are going to hit 22 to 23 PSI, but it will taper down. However, on 100 octane you will easily see 26 to 28 PSI because I am currently hitting that kind of boost with my stock turbo w/ a 10.5 hotside...
I would have just invested my money on either a greddy type s or a forge BOV. Anyways, its your money that your spending on the tune, whether boost holds or not...
THe question for me is (i could do a search, but I'm busy @ work) how much boost crushed 1G BOVs hold. I would assume the JDM MR valve is similar.
Brian
