New Bolt in turbo... FP White Rabbit.
Old Jun 28, 2005 | 08:18 AM
  #661
Az3ar's Avatar
DO NOT USE BOLTS, USE STUDS. studs withstand higher heat range and hold better than screws (fact). If your stud is stuck get it out and rethread DO NOT USE BOLTS. they will stretch over time and get stuck and welded on your turbo and your manifold so you end up with one big pile of garbage.
Old Jun 28, 2005 | 08:22 AM
  #662
DizzyTT's Avatar
That's funny, my damned studs broke trying to get the welded on nuts (all stock) off. I went to bolts after having to drill both studs out of the turbo.
Old Jun 28, 2005 | 08:26 AM
  #663
Knyght's Avatar
Thumbs down
You can't be serious...
I've been running 4 bolts on every one of my big pile of garbage DSM's for years now and never had a problem. In fact those are about the ONLY part thats held up the abuse. As far as 'getting stuck and welded on" thats what they make antiseize for. How can you even be serious when the stock system has 2 bolts and 2 studs? I guess you would suggest all four studs then right?
Old Jun 28, 2005 | 08:31 AM
  #664
pyrovice's Avatar
Anyone have Dyno numbers with cams yet?
Old Jun 28, 2005 | 01:02 PM
  #665
dryad001's Avatar
Here's my guess. It will probably make the 400+ mark with cams and a few other bolt on's running on 93-94 with some sort of EM (EMS, UTEC, Dynoflash)
But I am still waiting to see some numbers also. If anyone who has one I'd like to see a pull with pump instead of race fuel, and running a conservative tune.
Old Jun 28, 2005 | 01:09 PM
  #666
Jamie@WORKS's Avatar
Originally Posted by fury656
Would you mind listing the modifications on the car, most importantly whether or not you're running aftermarket cams. Would you say the WR upgrade wass worth it so far from the feel of the car? Also, are you running the full WR or stock turbo rebuild (03/05?). Thanks.
Here's a list of what Todd has on his car: https://www.evolutionm.net/forums/sh...&postcount=452
Old Jun 28, 2005 | 01:25 PM
  #667
NYREDEVO's Avatar
All this talk of 400+ HP range has me thinking....
What kind of safety measures should you be running? Either for you motor or tranny?
I feel like with my mods and this turbo I will break into the 425-450 range, Id like to avoid blowing things up! Any suggestions?
Old Jun 28, 2005 | 01:26 PM
  #668
Rez90's Avatar
i am just adding to this post because it's at 666.........everybody have a good day and lets get some dyno numbers on this pig.....or rabbit......whatever
Old Jun 28, 2005 | 01:30 PM
  #669
4-BNGR's Avatar
All you need is:
(1) The "Bunny"
(2) Walbro
(3) 660 injectors
(4) Cam gears (optional - but nice to have if you want to retard timing to prevent detonation)...
This assumes one already has "BPU's" on their car...
Old Jun 28, 2005 | 01:32 PM
  #670
Erik@MIL.SPEC's Avatar
Here's my "insurance" mods so far:
Walbro Fuel Pump
680cc injectors
ARP headstuds
ACT street clutch (even though my clutch has less than 5,000 miles and no problems).
Old Jun 28, 2005 | 01:40 PM
  #671
superman105's Avatar
atlvalet
are you getting your ECU flashed for injectors before the dyno day ?
Old Jun 28, 2005 | 01:47 PM
  #672
DOn't know how I'm going to do that. Shiv might have to do it @ the dyno day. Depending on when the dyno day is, my car may be at TT for Shiv to mess around with (he has my blessing). He may do it on his free time.
Old Jun 28, 2005 | 02:31 PM
  #673
Justin@Kingpin's Avatar
Originally Posted by 4-BNGR
All you need is:
(1) The "Bunny"
(2) Walbro
(3) 660 injectors
Detonation no .. .thats for subarus!
Old Jun 28, 2005 | 05:01 PM
  #674
pyrovice's Avatar
Scoobies are gonna be shaking in their boots, or slippers w/e
Old Jun 28, 2005 | 05:21 PM
  #675
Az3ar's Avatar
I am serious. Have you pushed your car a bit further than some road driving and racing? When you do please let me know.
I am suggesting to use studs not screws
