New Bolt in turbo... FP White Rabbit.
Old Jul 11, 2005 | 09:13 AM
  #1021
_007's Avatar
Originally Posted by DynoFlash
I wonder how long it will take to see some actual dyno sheets?
In order to make 441 whp without cams - IMHO - it would have to reach at least 30 - 33 psi of boost on that turbo.
I guess more patience is in order
What !!! 441 WHP without cams? I am going to go crazy if that is true. I will be the next king of the highway, because I am crazy enough to go Top Speed. Imagine the possobilities with so much power and a final gear..... Ohh man. Screw messing with cars. I am going to go after Bikes... AL, I can't wait to see what you can do to this turbo. Actually I might need a towel after you are done tuning it. for life.....
See you in Chicago soon
Old Jul 11, 2005 | 09:20 AM
  #1022
titaniumkingpin's Avatar
I too am only interested in how this turbo does at 20psi compared to the stocker.
Please people, don't forget to post your results after a run on the dyno.
Old Jul 11, 2005 | 09:21 AM
  #1023
Whoosh's Avatar
I'm the person robertrinaustin was talking about. I've just recently changed from the 3076 to the 35 and can tell you that they spool virtually the same. But where the 3076 starts going flatline on you, the 35 is really starting to shine. My power band is currently from about 4000 to 7500 rpm and it will just take your breath away. Huge difference between turbos.
Originally Posted by WrX Kila
How so?
  #1024
WrX Kila's Avatar
Cant wait for those results.
Old Jul 11, 2005 | 09:52 AM
  #1025
EVO8LTW's Avatar
Good point - especially if in more cases 20 psi is the most boost avisable to hold on pump gas. Which coincidentally is how much boost the stock turbos usually hold at the higher end of the power band.
Personally I do NOT care if the WR can make more power with MORE boost.
Why is running 23 psi a bad idea on pump if you have correspondingly adjusted timing advance? If this turbo can hold boost better at 23 psi, then it might make more power in the high rpms with more boost and less timing.
Old Jul 11, 2005 | 10:01 AM
  #1026
4G63>OOOO's Avatar
Just for argument's sake, can a GT35R make more power than a stock turbo at 20PSI or does it only make 500+HP when you crank it up to 35+?
Old Jul 11, 2005 | 10:16 AM
  #1027
EVO8LTW's Avatar
Definitely more power at 20 psi with a 35R.
Old Jul 11, 2005 | 10:17 AM
  #1028
Nez136's Avatar
bigger turbo=more CFM at the same PSI
Old Jul 11, 2005 | 10:23 AM
  #1029
_007's Avatar
Where are the RESULTS!!!!!
Old Jul 11, 2005 | 10:25 AM
  #1030
VTECH8TR's Avatar
Yes i personally witnessed an AMS built GT35R turboed evo and it made 360 whp at 16psi. Impressive to say the least.
Old Jul 11, 2005 | 10:32 AM
  #1031
Z1 Performance's Avatar
becuase the idea with pump gas tuning is to run the least amount of boost to net the power you want, not to limit your timing (torque), especially in the upper rpm ranges, just to say "I make/hold 23 psi to redline"
I too am interested to see how it really stacks up vs stock or vs the TM units - for most people. We know what the GT series turbos net on pump and race gas, just need to see how this stacks up against other known units.
Old Jul 11, 2005 | 10:38 AM
  #1032
zstryder's Avatar
Where are the pump gas numbers? I swear this is like a conspiracy or something..
Old Jul 11, 2005 | 10:45 AM
  #1033
_007's Avatar
What I don't understand is why does the Kit from AMS run $4,500 and then what ever for Installation. When I can get the same turbo that AMS has for $2,000 with Jethot Coated Headers and wastegate. I am missing the point here guys. The WR turbo is $1,500 ? Who comes up with these prices. Ok WR I understand because they have spent 2 years trying to perfect it and no doubt that thing will be amazing but the rest of the vendors, why is everything so much? I don't mean to rip on anyone and I will never do that, but it's just me. I want to know what I am paying for...... If it's the name or the actual product.
Old Jul 11, 2005 | 10:48 AM
  #1034
Nez136's Avatar
Im pretty sure just bolt-on turbos usually run from $1200-1500 depending on the upgrade, God knows who comes up with the pricing, we all know its not THAT expensive to make this stuff, companies like AMS, RNR, ect are making BANK on all these kits and the labor!
Old Jul 11, 2005 | 10:55 AM
  #1035
zstryder's Avatar
Two words:
Research and Development. That's almost ALWAYS where the cost goes. It's not the fabbing that actually costs a whole lot.
