Help Help ?
Old Jul 7, 2005 | 10:39 AM
love2burn420's Avatar
Help Help ?
I went to push my clutch in and when i did it stayed at the floor and will not come back up. And because of that it is not starting. What happened ? Please any help would be great, id like to know if its something i could fix or if ill have to go to the dealership. I have a exedy twin disk clutch?
Old Jul 7, 2005 | 10:45 AM
Now i pulled the clutch up by hand and it is very hard to push in. Still my car is not starting
Old Jul 7, 2005 | 10:46 AM
4-BNGR's Avatar
Did you bleed the clutch properly after the instal? Do you have clutch fluid the in the reservoir?
Old Jul 7, 2005 | 10:49 AM
Yeah ive put about 1000 miles on it since the install. Fluid is fine
Old Jul 7, 2005 | 10:56 AM
Jamie@WORKS's Avatar
Check at the slave cylinder to make sure the clutch fork/throw out bearing is still engaged with the ring assembly on the pressure plate.
Old Jul 7, 2005 | 10:58 AM
smokedmustang's Avatar
mine did the same, it was where the nipple meets the clutch/brake-line under the airbox, whereas I was pumping air in the system. re-bleed and check this line under the airbox, prob. solved
Old Jul 7, 2005 | 10:59 AM
Is there anyway i could check this in my driveway?
Old Jul 7, 2005 | 11:18 AM
yes remove the airbox, and there are 3-4 hoses comming into a "flute" looking thing. (Running from front to back) These hoses connect into a metal nipple, then into the "flute" Mine "seperated" from all the vibrations with my mods, and my mitshu mechanic custom made a bracket for me and it hasnt happened again, can take pix of it if interested!
Old Jul 7, 2005 | 11:25 AM
So i should take it to the dealer. My problem is that im in NY and dont know of any shops. Also i checked those hoses and didnt find any leaks of any kind.
Old Jul 7, 2005 | 11:57 AM
you are sucking in air somewhere, have them re-bleed the system a couple times, and see if it is just that you have air in the system, or a minute crack somewhere.
CahitGP034
Dec 30, 2015 11:45 AM
AWDTFTW
Jun 21, 2015 05:39 PM
crash1985
Mar 1, 2015 12:02 PM
Jib
South Region
Aug 11, 2006 07:22 PM
go2evo
73
May 31, 2005 09:51 PM
