Pounding the White Rabbit
Old Jul 22, 2005 | 01:28 PM
  #31
Blue Evo 8's Avatar
Originally Posted by DynoFlash
Next up - I am draining the pump gas - going to remove the line to the wastgate and run it max possible boost
The customer is selling this WR unit slightly pounded - 50 miles and 10 dyno pulls - for $1200 shipped
I pity the fool who shells out $1200 for this ....... might as well stick with a stock 05 turbo
  #32
evovette's Avatar
Lets not forget that the turbo its being compared to is a TME with a ball bearing center section, also not a cheap solution. I was going to make an argument for the WB based on how close it came HP wise, but my god the TQ diff is HUGE. Still the WR is I would assume 1/2 the cost of that TME BB
Old Jul 22, 2005 | 01:32 PM
  #33
Az3ar's Avatar
Sucky sucky
Old Jul 22, 2005 | 01:35 PM
  #34
EVO-8-Nate's Avatar
Thank you for helping me to not make a huge mistake. I was planning on the White Rabbit as a cheap solution to more HP. I am a firm believer that with the OEM turbo and some water/methanol injection I could match that easily.
-Nate
  #35
Jeff_Jeske's Avatar
The only people that could POSSIBLY benefit from the WR are 9.8 turbo folks. Even then if you did a CBA you would not want the WR. Personally I don't see why people would pay so much for such a little jump to begin with. If the stock turbo doesn't do it for you ....either get nitrous or go with something like a GT35R.
Old Jul 22, 2005 | 01:36 PM
  #36
PHILLY EVO's Avatar
Thumbs down
Who make this crap.....Don't you think they should defend it......
Old Jul 22, 2005 | 01:41 PM
  #37
DynoFlash's Avatar
This is true the Essex TME ball bearing is no cheap option I believe its about $1900.
This is NOT a test with WR against stock turbo or even TME turbo - - this is a test against the WR and a very high end exotic stock based high perfromance unit.
The main point was that the customer originally had the Essex unit and wanted to see if the WR unit could out do it
Soon i will have the 30 plus psi graphs (if the turbo will boost so high)
Old Jul 22, 2005 | 01:42 PM
  #38
gsujeff55's Avatar
LOL...going from stock to gt35..like there is nothing inbetween....you ever heard of driveability? or how about a road course, you do know the purpose of these things we call evo's don't you?
the stock turbo is a badass unit....i mean, 400whp on a 2L motor with the stock turbo is NOTHING to sneeze at. i dunno when people are gonna start maxing out their stocker before they jump on the upgrade bandwagon.
Old Jul 22, 2005 | 01:46 PM
  #39
EVO-8-Nate's Avatar
Whom ever can develope a cheap turbo for the consumer that wants 50AWHP more on pump will be a rich man! I might just have to start searching in Japan until we get something here.
-Nate
Old Jul 22, 2005 | 01:47 PM
  #40
tke_413's Avatar
For an extra $400 to the TME...look at that MASSIVE TORQUE DIFFERENCE!
  #41
gsujeff55's Avatar
need an internal wastegate td06 20g direct bolt on
Old Jul 22, 2005 | 01:48 PM
  #42
PHILLY EVO's Avatar
SO how much whp can the stocker put out......can you go mid 11's on the stock turbo....and then can the white trash I ment white rabbit do it for the price.......
Old Jul 22, 2005 | 01:52 PM
  #43
bolsen's Avatar
Originally Posted by Az3ar
Sucky sucky
5 dolla!
Old Jul 22, 2005 | 01:53 PM
  #44
Autogasm's Avatar
crap, that sucks
glad I waited
I'll hold on to my 1500.
Old Jul 22, 2005 | 01:59 PM
  #45
bdking57's Avatar
Al..you need to get your hands on an evo IX rs turbo and determine what kind of modifications are needed to make it fit. If i understand correctly, the evo IX turbo is the turbo of the future for the X... putting on the IX is sort of a test run? With the Ti internals and new larger design Id like to see if it can put out more power then this unit for alot less money.
