Pounding the White Rabbit
Old Jul 22, 2005 | 05:42 PM
  #61
03EvoVIII's Avatar
Originally Posted by titaniumkingpin
because its a 4" inlet.
I got this info from the guy who sell these turbos in UK. He also said that he is working to bring them over to a US vendor.
Okay.... then explain to me how this guy was running a dynoflased ecu with the turbo....
Old Jul 22, 2005 | 05:47 PM
  #62
Az3ar's Avatar
we should call it the wight bunny from now on.
Old Jul 22, 2005 | 05:48 PM
  #63
housedj's Avatar
Originally Posted by gsujeff55
the stock turbo is a badass unit....i mean, 400whp on a 2L motor with the stock turbo is NOTHING to sneeze at. i dunno when people are gonna start maxing out their stocker before they jump on the upgrade bandwagon.
i'm in the process of doing this now. yes i run my stock turbo out of it's efficiency range but who cares. if it blows up, i'll slap on a 25G anyway. also alot of people fail to realize that the stock (9.8) turbo is good for 500HP...
Old Jul 22, 2005 | 05:49 PM
  #64
Fourdoor's Avatar
Originally Posted by PHILLY EVO
whats the most made from stock
I made 411 wheel HP on a dynapack AWD dyno on the TME turbo. That was on race gas and 24.5 psi of boost with boost dropping to 18 by 8000 RPM as read on the AEM data logs, boost gauge reads 2 psi higher (26.5 psi down to 20 psi) and I didn't know what one to believe so I didn't go higher. Also I ran out of dyno time and was using the same ignition timing map as I used on pump gas daily driving. By upping the boost a couple more psi and playing with timing I would have been at or near 440 wheel HP.... perhaps beyond it.
Keith
  #65
housedj's Avatar
SO how much whp can the stocker put out......can you go mid 11's on the stock turbo....and then can the white trash I ment white rabbit do it for the price.......
if i remember correctly, Buschur went 10.24 on a stock turbo...
Old Jul 22, 2005 | 05:54 PM
  #66
housedj's Avatar
Thumbs up
Keith
you could have spiked to 32PSI & tapered it to 23 & made over 500WHP if you were using MoTec...
  #67
Fourdoor's Avatar
Not even close.
Curt Brown ran a very high 10 on the stock turbo with the motor tuned to within an inch of it's life. He holds the stock turbo record for ET and mph, but as far as I know he never dynoed the car with it sad to say.
Keith
Old Jul 22, 2005 | 08:09 PM
  #68
BBYBruno's Avatar
it says on their website 11.79@116 on stock turbo and pump.
Old Jul 22, 2005 | 08:24 PM
  #69
trinydex's Avatar
Originally Posted by metaphysical
Hrm, why haven't there been a lot of posts about this turbo from the UK? It seems to perform as well, if not better, than the WR, and it spools faster. It's too bad the Euro is high. On the other hand, maybe one of the vendors or tuners can work out a deal to be the official US retailer (maybe buy 10 to start).
because usually when you find something works... you just don't care about talkin' **** anymore. when you see a big ****fest going on in the internet forums... adn you know what's going on... why would you waste your time getting shot down by peopl that don't know ****... why would you wanna put in any effort, yer already set... and they have said stuff... just no one listens.
Old Jul 22, 2005 | 11:25 PM
  #70
Warrtalon's Avatar
Sure...uh huh.
Nice 13s at 25psi, btw.
Old Jul 22, 2005 | 11:28 PM
  #71
KILTERMAN's Avatar
Sure...uh huh.
LMAO
Old Jul 22, 2005 | 11:58 PM
  #72
Drews_WRX's Avatar
for all those haters out there....dont just take Als word that the WR sucks from this dyno test....maybe he just wants you guys to buy BR products....just a thought.
Old Jul 23, 2005 | 12:43 AM
  #73
EVOONYOASS's Avatar
wow....................just wow.
Old Jul 23, 2005 | 01:11 AM
  #74
DocMortal's Avatar
I would think AL would of loved this upgrade to work since everyone would need new reflashed ecu's and new road tunes = more business....
Hopefully other tuners will post their results also.
But for me so far its dissappointing,Ill stick with my plans on an AMS 3076 KIT with ALKY tuned by DYNOFLASH.
But thats just me.
Old Jul 23, 2005 | 01:35 AM
  #75
Erik@MIL.SPEC's Avatar
I have a WR, and I'm sorry but it builds boost better and more quickly than the stocker. Also, I don't know about Essex but the Evo400 turbo is about 1900...pounds. You're talking over 3000 USD there. Also, this guy had 264 cams. Perhaps the Rabbit runs better with 272s and cam gears? I mean, who knows. I admit I could be wrong, but it's way too early to judge this turbo. Also, when Shiv tuned the 2 WRs (including mine) he said the dyno doesn't show everything about this turbo.
What it comes down to is a bunch of internet hacks badmouthing a turbo they know not much about (this is not directed at any tuner). John Mueller and Tym Switzer have forgotten more about turbochargers than 90% of you will ever know. And both of those guys aren't in the business of trumpeting products that suck. Maybe that will sink into the heads of some of you. Jimmeny freakin' Cricket....
