Pounding the White Rabbit
Old Jul 24, 2005 | 11:32 AM
  #106
Precision Dyno's Avatar
Originally Posted by GPTourer
Hopefully, it will do better on some other cars. Disapointing, but I can't say I am really suprised. Especially after Buschur gave up trying to make a 20G wheel work in the stock housing.
IMO, the bottom line is nobody can make a better TD05H turbo then Mitsubishi. The skill that the shops like FP and Buschur and so on have could porbably make slight improvements in one direction, but might lose something somewhere else. But in the end the cost is just way too high for the gains.
The only problem with the Mitsu turbo is the thrust surface...
That will be corrected shortly....!
Otherwise they did a nice job on this turbo, for the street.
Old Jul 24, 2005 | 12:00 PM
  #107
DynoFlash's Avatar
Originally Posted by Tym Switzer
Al... just curious... I was looking at this dyno sheet trying to discern a few things regarding the conditions of the pulls and whatnot. I didn't see the conditions listed, and I noticed by looking at the times of the pulls that the turbo swap must have been done in minutes. Then I looked at the date of each run. The resolution is poor, but it looks to me like your baseline of the Essex unit was done back in March. I don't know about the weather conditions where you are right now, but it's been over 90 degrees here a lot the last few weeks. I'm also wondering what other mods may have transpired with the car or if it has developed any mechanical issues in the last 4-5 months. I was hoping you could elaborate.
I haven't been able to read through all of the posted threads regarding this turbo this past week, so I am catching up while at home. Hope you have time to give a few more details regarding this test.
Tym - March was the last time the customer was at the shop and was tuned at 27.5 psi which BTW is the maximum psi he can get with his HKS EVC V EBC set to 100%.
I do not think he changed anything since March other than the turbo
The Weather may have been different and that may have effected the results to some small degree.
The main point was that this customer has the $ to play about with turbos gave the WR a shot and in the end he seems to prefer his Essex ball bearing TME
I am sure that the WR would offer a significant improvment over a stock turbo at this high boost level - its a pleasant turbo and you can feel it pull harder up top. My only issue with it is that the gains seem modest compared to what my customers had previously expected.
Old Jul 24, 2005 | 12:03 PM
  #108
DynoFlash's Avatar
Originally Posted by 4G63>OOOO
Al, one question:
Does this car still have the 50 shot on it like it did in that 442tq dyno pull and when it ran the 11.8 last year?
Regards,
Joe - please put down the crack pipe OR pick up your glasses before you start posting !
The dyno sheet posted about was on pump gas with NO nos - its 412 tq not 442
Also - when Paul did hit the NOS on the old turbo he hit over 500 tq !
And - he was running NOS last year when he went 11.8 and also yesterday when he went 12.2
Old Jul 24, 2005 | 12:07 PM
  #109
DynoFlash's Avatar
Originally Posted by shiv@vishnu
Controlled testing? Come on now....
I don't consider any testing controlled unless I can find a suitable location to attach the air temp sensor.
I prefer uncontrolled testing - with a dyno jet it is what it is - the sheet speaks for itself.
Old Jul 24, 2005 | 01:09 PM
  #110
mitsuorder's Avatar
Wow... just wow. This just had to be quoted to go down in the books
And guys, I understand the dissapointment with some of the results yielded from the White Rabbit in comparison to the initial dyno sheets but do think, if this was another vendor's product my inbox would be overflowing with cries of "vendor bashing". I believe that FP is actually working on how to address the discrepancies found between the results of this turbo instead of cry about it. Also do remember that there are still different stages of the WR to come from what I understand.
Old Jul 24, 2005 | 05:10 PM
  #111
nefblkevo's Avatar
looks like to me that the WR really fattened up the torque curve vs. the '03 stocker from 3,500- 6,500 or so. Only question for me really is, is it worth the extra $500 over the 65RSTME
Paul
Old Jul 24, 2005 | 10:37 PM
  #112
housedj's Avatar
Thumbs down
Sure...uh huh.
Nice 13s at 25psi, btw.
since you like to run your mouth, come on out to phx & let's see what you REALLY run with an elevation here of 1320 ft, interior car temp averages of 143 F & track temps of over 160 degrees F!!! & those temps are at night BTW huh huh
DID I FORGET TO TELL YOU THAT MY 1/4 MILE TIME WAS ON 91 OCTANE **** GAS!!!!!!!!!!
Old Jul 24, 2005 | 11:10 PM
  #113
Warrtalon's Avatar
So it wasn't on the 101 in your sig while running 25psi? No one is dumb enough to run 25psi in extreme heat on 91oct. Every other time we've talked about this, you claimed you were running 25psi with no problem. Care to fix your story? I'll be running at 5800 ft in a few months, but it won't be quite as hot.
Old Jul 24, 2005 | 11:12 PM
  #114
KILTERMAN's Avatar
Once again. OWNED. Sorry HouseDJ, But he got ya, again.
Old Jul 24, 2005 | 11:40 PM
  #115
ElAnCeR's Avatar
Weren't we talking about the WR turbo in this thread?
Old Jul 25, 2005 | 03:23 AM
  #116
GPTourer's Avatar
Oh, I am definitely not saying it is perfect, but it is definitely overbuilt for the stock output that it is set at. When the Evo IX comes out it will probably have a better turbo then the VIII and the WR. Without cheap 50 trim or 60-1 bolt on options, it just makes more sense to to me to go big after getting tired of the stock turbo and up to a GT35R or beyond.
Old Jul 25, 2005 | 07:12 AM
  #117
Blue Evo 8's Avatar
Would someone put a bullet into this white rabbits head already??
Old Jul 25, 2005 | 07:57 AM
  #118
TURBODAWG's Avatar
Max boost with line to wastegate disconnected was 28 psi - max top boost.
The car actually lost power with the extra .5 psi of boost - lost 2 whp
It ran great on the road - fantastic - really nice. Someone comming from a stock turbo would feel a nice kick in the pants especially on the top end. BUT - it does loose out a lot of low end tq compared to the Essex TME unit.
The customer went 11.8 last year with the other turbo 0- he is going to the track tomorrow to test the WR and see how it does on the track.
What BOV is he using?
It doesnt list it in the mods section, but I am assuming it is not the stock BOV. If he doesnt run one of a few BOVs he will be leaking off most of the additional boost that the WR turbo can provide. That turbo should easily spike to over 30+ psi initially with no wastegate line.
Brian
Old Jul 25, 2005 | 09:41 AM
  #119
NYREDEVO's Avatar
Maybe it's just me but wasn't the white rabbit tested on a car without cams? So far every WR thats been tested after(at least that I have see) has been on cars equiped WITH cams. Could that be the reason that this turbo is not performing as well as it did in Switzer's test?
Old Jul 25, 2005 | 10:53 AM
  #120
Erik@MIL.SPEC's Avatar
My car has no cams or cam gears. On a 100 octane map, my car with a high flow cat put down almost the same exact horsepower numbers as a TME with cams and a test pipe. In fact, the TME car went on the dyno right after me. That's about as close as you can get conditions wise. The dyno charts are on the Vishnu TT Muy Caliente thread.
On 91, he made more in the power band where you'd think he'd make more running the cams he is. His cam gears are set to 0,0.
