Prototype Bolt-On Turbo Testing
Old Nov 14, 2005 | 07:33 PM
  #196
Mr. Stock's Avatar
Typically, it runs me about $600 to upgrade a compressor wheel on a turbo. Garrett GT-spec wheels generally run $225 or so and the rest is machining of the compressor cover, rebuild, balance, etc...I've spent about that upgrading a mitsu-based T78 and a GT4082 to a 4088. Both much larger turbos.
I guess the only difference here is the custom reverse wheel (I'm assuming billet?) and very limited quantities?
Old Nov 22, 2005 | 04:30 PM
  #197
954DRGSR's Avatar
Que pasa
Bump 4 updates.
Old Dec 20, 2005 | 05:06 PM
  #198
954DRGSR's Avatar
Ss55?
Originally Posted by 954DRGSR
Bump 4 updates.
Again, what that guy said.
Old Dec 20, 2005 | 05:36 PM
  #199
rACerS's Avatar
ditto
Old Dec 28, 2005 | 04:58 PM
  #200
954DRGSR's Avatar
Originally Posted by rACerS
ditto
Exactly.
Old Dec 28, 2005 | 06:11 PM
  #201
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Unfortunately, they are unable to get the wheels and it looks like the project will die because of this. As of this week, they are still not in the US, though they have been waiting since just before I started this thread. I guess someone doesn't want this turbo built.
Old Dec 28, 2005 | 08:13 PM
  #202
rACerS's Avatar
thats to bad
Old Dec 28, 2005 | 10:07 PM
  #203
PurgeIt's Avatar
All that hype... and now it's dead.... Sad....
Old Dec 29, 2005 | 02:47 AM
  #204
David Buschur's Avatar
I would like to chime in on this, sure it is going to cause problems but that's O.K.
All I want to point out is the dyno sheet.
The base pull was obviously done with a lousy tune or something else wrong with the car. A stock turbo, if tuned correctly will pull atleast a flat HP line to 7,000, if not climb all the way to 7,000 rpm. The 70 whp with the cam/turbo upgrade is actually gained at 7,000 rpm where after the install of the cams/turbo the car obviously was tuned much better.
I think to get a better idea of what the gains should have been you need to look at the graph before the base pull WHP started to fall. There it looks like 25 whp or so.
I'm not being negative or knocking the turbo. There's plenty of business for all of us. I am just pointing out the fact that the two charts aren't a very good comparison as the first one just..........stunk.
Good times you are running the car, congrats.
David Buschur
www.buschurracing.com
Old Jan 23, 2006 | 06:49 AM
  #205
954DRGSR's Avatar
This is really unfortunate. It looked promising.
nickelndime
Sep 19, 2017 06:49 PM
Hiboost
26
Dec 30, 2009 04:28 PM
scheides
Aug 31, 2009 04:34 AM
robertrinaustin
Site Feedback / Suggestions
39
Feb 23, 2008 12:58 PM
AMS
55
Sep 2, 2003 04:07 AM
