Oil thread
Old Nov 1, 2005 | 04:36 PM
M3ss's Avatar
Oil thread
I just checked my oil level and it's almost a quart low is this normal? It's my first time checking it and the car has 2,400 miles on it and hasn't been changed yet! Should i worry ?
Old Nov 1, 2005 | 04:43 PM
ZK's Avatar
ZK
I have a similar problem on my car. 3K miles and low 1/4 quart. I just topped it off. Apparently this is pretty normal on Evos.
Old Nov 1, 2005 | 04:44 PM
ex-honda's Avatar
It depends on how you drive it. If you drive it hard alot then you will use some oil and since it's still new, everything is still "sitting" in. I would suggest you change you oil now. Metal particles will circulate and might due some damage. On a new car/engine, most of us have our first oil change around 700-1000 miles.
Old Nov 1, 2005 | 08:01 PM
BURNALL_4's Avatar
i did my oil change at like 1000 and by the first 750 i was almost a quart low. its got 3400 now just put in 1/4 of a quart its going to sit all winter starting it once in a while. first thing in the spring is an oil change. so to answer your question i am going to say its completely normal, top it off and have some fun, of cource be safe.
Old Nov 2, 2005 | 07:48 PM
Deepseadiver's Avatar
I wouldent worry too much about being a quart low. Did you check it when you first got it home? You might have got it low.
Old Nov 3, 2005 | 11:29 AM
shivaswrath's Avatar
that doesn't sound right, maybe u didn't break it in properly, I have 3200 on the clock and my oil level hasn't ever dipped. . .I was good about the break in, were you?
Old Nov 3, 2005 | 12:11 PM
ZK's Avatar
ZK
I did nothing above 5K rpm and no more than 50% throttle for the first 1200 miles then changed the oil. now at 3K some oil disappears. Even now, 90% of the time I do not go over 5K rpm or 50% throttle when driving around. So it is definitely not because of hard driving. My car barely knows what boost is like.
Old Nov 3, 2005 | 12:18 PM
Cali2MDevo8's Avatar
Registered User
From what i thought, low oil was common for the sub 1000 mile evo's. But you have more than that. Break-in is complete. I would change the oil and make sure the oil filter is ok. Maybe the rings didn't break-in correctly. Blow by.
Old Nov 3, 2005 | 12:20 PM
Registered User
My EVO has under 200 miles and i smell an oil smell since the first time i drove it. I'm guessing i should check my oil level occasionally as well.
Old Nov 4, 2005 | 03:25 PM
fletch's Avatar
I haven't lossed any yet either at least at 1k or so no loss. Changing soon to Royale Purple. It's at 1375 now.
Old Nov 4, 2005 | 11:04 PM
M3ss's Avatar
Yes i was ! And i was **** about it too as it's my first new car!
Old Nov 4, 2005 | 11:07 PM
M3ss's Avatar
2,500 miles on it now!
well i had the oil changed today along with the 1k inspection today and they said everything is ok!
Old Nov 5, 2005 | 03:07 PM
Greg Haymann's Avatar
Check all your fluids.My previous 03 evo was low at the tranny and rear diff.Oil never a problem.New car everything came good and no oil burning.
Old Nov 7, 2005 | 01:26 PM
05SilverEvoVIII's Avatar
1050 still good here. Need to change fluids. But still good on the oil level.
snowpro4g63
Nov 29, 2016 09:57 AM
Frew
16
Oct 30, 2012 01:13 PM
EVOLUTION Vlll
14
Aug 31, 2008 03:54 PM
Turbodemon
23
Jul 22, 2008 09:24 PM
5StarSuzuki
23
Oct 8, 2003 05:21 AM
