Tilton Clutch Install
Old Dec 7, 2005 | 01:30 PM
  #106
TTP Engineering's Avatar
Originally Posted by joeymia
Ok I spoke with Tilton and the restrictor they are testing is a one a way restrictor to reduce the shock on the drivetrain when launching. Not something that will improve daily driving. He did however give me some tips on how to properly use the clutch for daily driving situations. He said to take my foot off the clutch slowly until it starts to slip a bit. I can do this for about one car length without really affecting clutch life. Its not like the stock clutch where you can give it some gas and just remove you foot off the clutch. I was able to drive pretty nicely with that technique but I thought it was bad for the clutch. He said its worse to just let off quickly once the car starts moving. Anymore tips would greatly be appreciated because this is definatly a tricky clutch to get used to.
Good to know, thanks for the info Joey!
Old Dec 7, 2005 | 02:00 PM
  #107
BADEVO's Avatar
Joey - Has it been fairly easy to get used to driving this thing in traffic ? I know you had some issues, but can you overcome that pretty qucikly?
Old Dec 7, 2005 | 02:25 PM
  #108
joeymia's Avatar
Well its not that bad because miami is flat. It would be a pain in the *** to get stuck on a incline with this clutch. If your lazy with the clutch or already hate driving stick then you better really think about getting this. Once I felt the very noticeable low end torque increase and was able to shift lightning fast I didn't care about the driveability of the thing I have over 300 miles on the clutch so far. A ton of which has been city driving and I have yet to miss a single shift. With the old clutch I would grind atleast once daily.
Old Dec 7, 2005 | 03:12 PM
  #109
ez's Avatar
ez
Makes sense...I have never had to replace one of this design...
Originally Posted by 03EVO583
Tilton has been producing concentric slave cylinder (hydraulic release bearings) since the early 1980s. Many car manufacturers are now incorporating this type of design in the new cars they produce. Tilton does not have a patent on them, but they do have very proven design and the highest quality.
Old Dec 7, 2005 | 03:14 PM
  #110
ez's Avatar
ez
Oh and my apologies for the hijack. Thanks to all for the great testing information in this thread!
Old Dec 7, 2005 | 03:35 PM
  #111
sureshot!'s Avatar
Old Dec 7, 2005 | 04:33 PM
  #112
joeymia's Avatar
real test is this sunday at the track
Old Dec 7, 2005 | 06:11 PM
  #113
SEEYA's Avatar
this is what i am looking forward to hearing about...i just need to find some time to install mine now....
Old Dec 14, 2005 | 11:57 PM
  #114
ICE888's Avatar
I was wondering how you made the bump stop for the clutch pedal? Thanks
Alfred
Old Dec 15, 2005 | 12:03 AM
  #115
joeymia's Avatar
Alfred
bump stop is probally other applications. I did not need one on the evo. Adjusting the clutch engagement is a must however. BTW I have yet to miss a shift with this clutch.
Old Dec 15, 2005 | 12:04 AM
  #116
joeymia's Avatar
I wasn't allowed to race on sunday because I lacked a kill switch for my battery. I was not aware you needed one for a relocated battery This Friday if the weather is ok I will try again
Old Dec 16, 2005 | 11:44 PM
  #117
joeymia's Avatar
Finally ran the car in the 1/4 mile. The clutch worked flawless. I ended up setting up my launch rpm to 6500 and just dropping the clutch. I think I did great for my first time out. Check out this thread for pics and video.
https://www.evolutionm.net/forums/sh...d.php?t=174789
Old Dec 18, 2005 | 10:47 PM
  #118
joeymia's Avatar
http://72.41.83.159/video/hialeah-12-17-05.wmv
AutoX run with an instructor. BTW the man was over 6' tall and atleast 250-300lbs. He was a freaking tank !!! Nice guy helped me improve my times and gave me lots of tips. As you can see at 6k RPM with about 8lbs of boost even with the extra weight the car launched great. I still do not slip the clutch I just dump it.
Old Dec 19, 2005 | 12:09 AM
  #119
SEEYA's Avatar
nice run...
Old Dec 22, 2005 | 11:06 PM
  #120
ICE888's Avatar
Joey
Have a quick question for you, is your clutch making weird noises? I have this weird sound where when you try and feather the clutch, or when you first engage the clutch and try and feather out. Is sounds like a loud honk. I can repeatly do this is I step in the clutch and feather out again. Any ideas?
Alfred
