Carbon Fiber Drive Shafts
thanks for the update, I am doing a small build with AMS now and would like to get it turn key with some of your shafts...
Are they going to be able to stand 700hp for drags and a track attack car.....???????
Originally Posted by Kee1pride
are chances of them breaking larger than the stock one breaking?
If the CF units use beefed-up U-joints, then the point of failure would be shifted back to the shaft, but the shock-absorption characteristics and incredible strength of the CF shafts would make failure very unlikely for all but the highest horsepower cars.
Originally Posted by 1slowevo
The shaft we are doing is a full replacement of all three pieces not just the rear 2.
I spoke to ACPT at PRI in Orlando last week. They said the Evo shaft is coming soon, they are working with AMS to make it happen. The delays are because they are trying to make it a 1-piece shaft. Price should be around $1,200.
For those that dont know what a light weight driveshaft does in terms of performance it increases power at the wheels as there is less drivetrain loss. It can be considered more of a percentage number, as someone making 500HP will see more of an increase over someone who is stock. Also, like stated earlier, it removes stress from components.
You didn't get a reply bc last week they were busy prepping for PRI.
ACPT makes the tubes, the shop in TX makes the u-joints because you can't buy just a u-joint from Mits. Not sure who actually attaches the tube to the u-joint, but when you buy it, it will have an ACPT sticker on it ;-)
I sent the email to the shop in TX they are the ones that are building it not ACPT.
When I was in Orlando, at PRI, I was standing in the ACPT booth talking to a guy in a shirt that said ACPT and weaing a name badge that also said ACPT and he said they were making one and didn't mention any other shops.
And I misspoke about AMS's involvement earlier, they are working with DSS on an aluminum one and have nothing to do with ACPT. I re-checked my notes, hope I didn't create any confusion.
Then I guess we're talking about two different things. Or maybe there will soon be two more carbon fiber driveshaft options for Evo owners.
I have been going back and forth with James at ACPT , even sent him a stock drive shaft to use as a mock up and its been a long time, but I have heard from James that it is in its final stages.
