Another 20G-9 MONSTER HP chart...
Old Jan 27, 2006 | 03:53 PM
  #76
4G63 T's Avatar
I wonder how much lower the number with pump gas?
Old Jan 28, 2006 | 09:44 AM
  #77
ogvw's Avatar
here is a small vid clip of the idle on my car when testing started a year and a half ago. The car was running only a reflash and cam gears - no stalling occured.
right click - save as!
hopefully David will post vids of his RS, I am sure it sounds a bit meaner
Old Jan 28, 2006 | 11:12 AM
  #78
1StockEvo's Avatar
Revolver cams
I will be posting my dyno sheets within the next couple of weeks.
Old Jan 28, 2006 | 12:03 PM
  #79
Hannibal Smith's Avatar
I know it would be a waste of a little money but I was wondering if I could install just the exhaust cam, springs, and retainers on my EVO 9? Would the Revolver exhaust cam net me any more power than a 280 HKS exhaust cam? I would purchase the complete Revolver intake/exhaust cam set and use just the exhaust cam if Dave thinks just the exhaust cam would be worth it for a EVO 9 Mivec head.
Old Jan 29, 2006 | 10:37 AM
  #80
swordfish's Avatar
Tell me something about this 20G compressor....... Is it the same design as the 25+ year old 20G from the days of yore but machined as a reverse rotation wheel, or is it a redesigned wheel that Buschur just happens to call the 20G because of its characteristics.
If it is indeed a backward version of the old 20G (which is a diesel compressor from a fuso truck) then these numbers, along with the numbers in the EVOONYOASS (?) thread are astounding. To get that much power out of a wheel that small in a housing not designed with that wheel in mind is just mind boggling. I cant believe that anyone who claims to know anything about turbos is not floored by the results.
You guys are wringing this poor little compressor to within an inch of its life. My hats off to you for getting it to make this kind of power. Especially using a wheel design from circa 1978.
jeff
Old Jan 29, 2006 | 06:21 PM
  #81
NYREDEVO's Avatar
Any1 know if u can run a stock I/c with the 20G-9? I think I saw something about it on another thread but I dont rember where...
Old Jan 29, 2006 | 07:30 PM
  #82
Erik@MIL.SPEC's Avatar
Of course you can.
Old Jan 29, 2006 | 08:05 PM
  #83
NYREDEVO's Avatar
Oh...ok cool - i thought I read somewhere that the stock lower ic pipes had clearance issue
Old Jan 29, 2006 | 08:09 PM
  #84
RSGuy's Avatar
You could but the stock fmic is maxed out at 400whp. This 20G is capable of more than that on pump gas.
Old Jan 30, 2006 | 12:06 AM
  #85
trinydex's Avatar
you can still run it regardless... it will just cap yer power potential... technically your everything limits you in horsepower somewhere.... but we're not all tryinna build race cars.
the lower ic pipes do have clearance issues... or rather you can't use a stock lower ic pipe with the evo 9 turbo with anything besides an evo 9. if you ahve any other model then you'll have to get the lower ic pipe mounting or whatever kit from br.
Old Jan 30, 2006 | 07:30 AM
  #86
CarFanatic's Avatar
I'm confused about the 20g-9? is that a model number or a turbo of the new evo 9?
Old Jan 30, 2006 | 07:43 AM
  #87
deadbeatrec's Avatar
its the new evo 9 16g turbo rebuild to 20g specs.
Old Jan 30, 2006 | 08:33 AM
  #88
CarFanatic's Avatar
ah! thanks man, I was confused about that.
Old Jan 30, 2006 | 10:29 AM
  #89
NYREDEVO's Avatar
Thanks man, thats what I thought.... I guess that works out for the better anyway - I needed to replace my lower ic pipes anyway!
Old Jan 30, 2006 | 01:07 PM
  #90
Most-Wanted's Avatar
David, any more info on these cams for a IX set up?
