GSC Power-Division EVO 9 Cams
Greg: With your upcoming IX 280 intake cam can we run one of your 272 VIII exhaust cams and that way have a staggered 280/272 setup on an Evo IX? I am thinking of buying a IX soon and I like the 280/272 combo.
Originally Posted by GregGSC
here is something close. i dont really have anything with the utec but this what the car made after big al tuned it. @22psi
My IX made 355whp on that same dyno with just an exhaust and MBC set to 22psi (stock cams), tuned by Al.
Most IX's are making around 340-350whp on Pruven's dyno with just exhausts and boost controllers when Al's tuning them.
I would hope to see an IX make around 370-380whp on that dyno with exhaust, MBC, fuel pump and your cams.
Originally Posted by bernardo
Greg, I'm curious to see if there were any other mods on that car (ie: TBE). I hope the only mod on your car was the cams because that's not very big HP if there were any other mods.
That was an evo 8. Not a IX. Look at the date on the dyno sheet.
Also you must have a bad *** tuner!!! I have seen stock evo 9's dyno and they are gettin tops 250 to the wheels. And my buddy has a 9 and he has close to the same mods i do with ECUtec tuned and he is pushing like 350 to the wheels.
yes you can, I am kind of wanting to see what that setup will do, as well as you. Feel like being a ginnie pig?
Originally Posted by 3000ways
Is this at Mynes, don't they use a Mustang Dyno. 250WHP tops, seem very low to me, maybe the gas is sh*tty over there in Arizona, what do VIIIs dyno on the same Dyno?
Stock for stock VIII's and IX's put down similar numbers per Shiv and Buschur. It is after a reflash that the gains become apparent.
FWIW, when I got tuned the car before me was a VIII with 255pump, FMIC, cams, MBC, TBE no cat, all hardpiping, intake etc. A full BR stg 4 car. He did 275whp on 93 pump. I went after him with TBE w/ hi-flo cat, MBC, BR intake and did 280whp on 93. Both tuned by Al on Buschur's dyno.
Comparing an VIII to a IX is about the same as comparing an LS1 to a LT1 for the most part.
Girlei
