How much cam overlap is ok ?
if you're putting on a turbo that big, you better already have a good understanding of what overlap is, and is acceptable, or you're in for a big, big dissappointment.
Originally Posted by a1091156
Scavenging effect is more important with normaly Aspirated Engines........
Just wondering how much power certain durations of overlap may cost on a 65lbs/min compressor wheel output.......
Well, ok to be precise, reversion costs power..........which can be affected by overlap depending on the Exhaust manifold, Turbine size, Turbine A/R & Exhuast..........I think it'll just be easier to stick it on the dyno and see how we go adjusting it via a set of pulleys
And like dubble said about the personal preferance, cars are different, your set up is different from everyone else, you will only find out how much is too much from your own R&D when tuning your car.
Nevertheless, zero overlap is definitely NOT the best arrangement. Turbo cars benefit from overlap until or unless a high PR creates reversion.
So long as there isn't a high PR situation caused by a poor choice of turbo, restrictive exhaust manifold, or restrictive turbine housing, overlap is your friend, not your enemy.
AFAIK, zero camshaft overlap exists only in the the theoretical design of a 4 cycle Internal Combustion engine (Otto cycle). Very early on, probably 100 yrs ago, they found zero overlap was far from optimum as it does not allow enough time for the intake and exhaust to optimally function so they increased the duration on both. There probably hasn't been a zero overlap automotive IC engine built since?
211Ratsbud
Dec 24, 2016 10:09 AM
