Please Help me figure this out!!
Old Jul 27, 2006 | 02:56 PM
DjTyTanium's Avatar
To start off I own an 04' RS with 40,000 miles. Ok so last night (after letting a friend drive my car in exachange to drive his exige) I started having problems. I hit a hairpin at about 35-40 which my car can usually handle but the back slipped out nasty and I almost hit the wall.... Than while on the freeway I hit boost but than it felt like boost and power was dropping out. Almost like the car could not figure out how to put power down. No check engine lights so it leads me to believe it is something with the tranny? Maybe Transfer case or differentials? Someone please help me figure out what this could be.... I am confused as hell!!
-Tyler
Old Jul 27, 2006 | 03:07 PM
Evolution8Blue's Avatar
do you have acd or no?
The car kicking out on you happens sometimes mine kicked on my randomly once i was pissed because i pound on it on corners then one day i was taking one somewhat normal and it whiped.....
Old Jul 27, 2006 | 03:11 PM
DjTyTanium's Avatar
No ACD but it happened a second time I went around a corner as well... and the power dropping out has never happened before... it really feels like the car is struggling to put power down..
Old Jul 27, 2006 | 03:13 PM
bluebyu36's Avatar
how are your tires there proably getting bald,and maybe the lack of power was just the humidy reset the ecu,maybe bad gas i dont know,just dont let nobody drive your car and what kind of car did he have?
Old Jul 27, 2006 | 03:15 PM
DjTyTanium's Avatar
he drives a lotus exige... but he just bought it and is new to stick.... I never let anyone drive my car but I wanted to smash the exige... he told me he had a few really nasty downshifts were he did not rev match and just let it buck badly.... he was being honest with me at least... but yeah my tires are bad.... I will try resetting my ECU to see if it fixes the power problem... Id me much happier if that got cleared up...
Old Jul 27, 2006 | 03:50 PM
tony_b's Avatar
This is the main reason NOONE but me gets behind the wheel.
Even if he didn't rev match, it would'nt cause "bucking". It would just cause the rpms to go up as you let the clutch out instead of before.
You sure he didn't say nasty launches instead of downshifts?
Old Jul 27, 2006 | 03:53 PM
DjTyTanium's Avatar
I am resetting my ECU as I write this...Also I have never changed my transmission/differential fluids... I have 40,000 miles on my car right now.... should I change the fluids and see what happens??
Old Jul 27, 2006 | 04:00 PM
DjTyTanium's Avatar
well I guess not necessarily bucking.... but you know if your driving hard and your going to downshift and you dont rev match and you just shove it in gear and dump the clutch that nasty feeling you get... thats what he has explained to me he did...He was behind me the whole time there was no launching... I guess just horrible clutch work...clutch is fine though....thats why im confused.... most clutches would go out before anything in your tranny...
Old Jul 27, 2006 | 04:50 PM
sonicnofadz's Avatar
40,000 miles and you never changed the fluids!? Hrmmmm you might want to consider doing that ASAP. Also, make sure there are no boost leaks or anything, maybe he popped off something on the intake tract. How did you like the lotus?
Old Jul 27, 2006 | 05:14 PM
EvO6-RS2's Avatar
Clutch??? Might be slipping....you smell anything? Is it a stock clutch or upgraded?
Ferp
Jul 13, 2023 07:31 PM
Y_U_no_run_evo
16
Dec 16, 2016 04:01 PM
Corrupter
Aug 29, 2015 07:40 AM
redaxelnos
11
Jan 24, 2011 05:25 PM
EvoJoeIX
Apr 25, 2010 02:15 PM
