Best downpipe on a IX??? Fitment/quality/craftsmanship/performance
Old Oct 25, 2006 | 12:00 PM
  #166
*sam*'s Avatar
So how much WHP are we looking at switching from a 2.75 to 3.0?
Old Oct 25, 2006 | 01:16 PM
  #167
PnutButterWolf's Avatar
Originally Posted by davidbuschur
The MIVEC is not going to effec the flow of the exhaust after the turbine wheel. A 3" downpipe is going to make more power than a 2.5 or 2.75" on a car making any decent power at all. It is NOT going to hurt the power of even a low powered EVO. There is NO reason to NOT use a 3" downpipe UNLESS you are going to attach it to the stock catalytic converter. IF you are sticking with the stock cat then use a 2.5" downpipe, otherwise, go with 3".
End of story. Will race for money.
it seems the 2.75" make more tq on pump gas
Old Oct 25, 2006 | 01:29 PM
  #168
David Buschur's Avatar
Anyone wanting to continue to argue about donwpipes please refer to the post that Zeus made from the engineer at Garret.
Old Oct 25, 2006 | 04:35 PM
  #169
Gruppe-S's Avatar
Hehe well said Dave. If the 3.0" fits (and many do) go with the 3.0".
Incidently Helix V2 downpipes and test pipes in stock.
As for more torque, more torque is achievable by by pushing more boost pressure. Cars with superiour boost management systems (for example an AVC-R) will have better boost curves and thus torque curves than a manual boost controller. For this reason, comparing a 2.75" to a 3.0" on separate cars with separate setups is comparing apples to oranges.
Cheers,
Gary
Gruppe-S
Old Oct 25, 2006 | 11:47 PM
  #170
TTP Engineering's Avatar
Originally Posted by Gruppe-S
I like what Dave said because it's all true. If you want to stick with the stock turbo, think about 2.5", it'll be fine. If you want to upgrade your turbo or make some big power run a 3.0". If and when the motor mounts start to sag get a Cusco V2 brace or some spacers. If you happen to find a 2.75" for cheap or your buddy gives you one, go for it!
Cheers,
Gary
Gruppe-S
Stock downpipe is about 2.5" so paying $399 for an HKS unit is the biggest joke of the aftermarket DP world.
We have 25, 3" mandrel bent, robotic tig welded, stainless steel polished units in stock for $165 shipped. While others are taking the opportunity to plug their products, we might as well also.
Old Oct 26, 2006 | 07:38 AM
  #171
mrfred's Avatar
Do you know if your DP will clear the Cusco Type II LAB brace?
Old Oct 26, 2006 | 09:31 AM
  #172
If its the blue 2-piece then yes. As it is actually lower than the stock tie bars.
Old Oct 26, 2006 | 04:27 PM
  #173
trinydex's Avatar
who cares get the tanabe one that clears your dp hahaha
Old Oct 26, 2006 | 05:06 PM
  #174
mrfred's Avatar
?? I've already purchased and installed a Cusco Type II brace.
Old Oct 27, 2006 | 05:46 AM
  #175
CoreyR's Avatar
David,
Real quick question. Are we talking peak power here or are you saying that a 3" DP will make more power throughout the entire RPM range? Let's assume a 3" exhaust from the DP back. Also assume no tune, or a tune without increasing boost.
I'm trying to figure out if a 3" DP will sacrifice ANY low end TQ to a smaller DP.
Thanks!
Corey #89 STU
Old Oct 27, 2006 | 06:17 AM
  #176
A 3" will make more power if mated to a 3" cat/offroad pipe and catback than using a smaller diamer pipe, this is throughout the RPM range.
Old Oct 27, 2006 | 06:38 AM
  #177
CoreyR's Avatar
Thanks! BTW... we just installed your 3" V-band system on a buddies EVO last night. I've never seen anything fit so good!
Old Oct 27, 2006 | 09:14 PM
  #178
socalmr's Avatar
i have the buschur v-band, and it definitely fits like a glove, no leaks and very easy to install.
highly recommended!!!!!!
sounds good, lightweight, perfect fit, good power - oh yea!!!
Old Oct 28, 2006 | 08:23 PM
  #179
EVO_EDGE's Avatar
Fujistubo
Old Oct 28, 2006 | 08:26 PM
  #180
socalmr's Avatar
i have buschur and it fits perfect!!!
