Best downpipe on a IX??? Fitment/quality/craftsmanship/performance
Old Mar 5, 2008 | 04:12 AM
  #256
gsrix's Avatar
Originally Posted by TTP Engineering
We have about 7 units left in stock.
Hi,
Did you have a Megan Racing D/P in stock,for evo 9 2006 w/ACD.
pm me for the price, Thank you
Old Mar 5, 2008 | 07:20 AM
  #257
TTP Engineering's Avatar
Originally Posted by gsrix
Hi,
Yes. In stock shipping daily.
Old Mar 12, 2008 | 08:08 AM
  #258
mrfred's Avatar
Finally installed my Helix v2 DP this morning. Even with the entire DP wrapped with exhaust wrap, fitment is excellent with > 3/8" clearance from the oil pan and 1/4" clearance from the ACD. It clears the Cusco LAB #1 brace (ties the two A arm bars together), but it does not clear the Cusco LAB #2 brace (the one that replaces the two stock tie bars). I'll probably need to install 1/2" spacers there. Would have been nice if it cleared the LAB #2 brace, but its worth it for the otherwise excellent quality and fitment. BTW, if you have a LAB #1 and #2 brace installed, plan on having to remove them to get the DP on there. No way around it.
Old Mar 12, 2008 | 08:10 AM
  #259
injentech42's Avatar
i like my rsr with greddy tic sounds awesome
Old Mar 12, 2008 | 07:41 PM
  #260
SPANKED's Avatar
So would it fit the stock tie bars if you had those on?
Old Mar 12, 2008 | 08:12 PM
  #261
mrfred's Avatar
I think so. The stock tie bars are more narrow. At worst, a few spacer washers would be needed.
Old Mar 12, 2008 | 08:30 PM
  #262
evospecialist's Avatar
dc sports hard to find but fitment is awesome.
Old Mar 12, 2008 | 08:35 PM
  #263
DJmarkymark's Avatar
my Agency Power fits like a glove and clears everything
plus, its a full 3inches
Old Mar 12, 2008 | 10:42 PM
  #264
PnutButterWolf's Avatar
I have tried Helix ver1, Megan downpipe, and now I am on my 3rd Downpipe.
All I can say is that my current Tanabe 2.75" downpipe fits like a glove and with very ample clearance between transfercase and oil pan compared to the other two that I had before. I like the 2.75"s low end response much better. The flat spot during low RPMS in 3" dp is no longer there.
my setup FP Green, Denso 720cc injectors, AEM short ram, walbro pump, Titek o2 housing, Tanabe 2.75", RRE rally cat, Tanabe Medalion Touring, GM 3port boost solenoid and tuned by Andy @speed Element.
Old Mar 18, 2008 | 05:50 PM
  #265
TurboErik's Avatar
a dong bong bing bong Ticky ticky thought of a gun ...
Old Mar 18, 2008 | 06:03 PM
  #266
mrfred's Avatar
Thought I made a mistake until I found this pic on the Agency Power website. It takes about 1" of spacers for the Cusco LAB II bar to clear the Agence Power DP. It only took about 3/8" of spacers for my Cusco LAB II bar to clear the Helix v2 DP.
Old Mar 19, 2008 | 02:52 AM
  #267
SunKren's Avatar
Can you explain a lil bit more about the difference in low RPMs between 3" and 2.75" DP?
And does anyone know if it is true that aftermarket exhaust hangers really kill the rattle problems?
Old Mar 19, 2008 | 04:42 AM
  #268
mrfred's Avatar
Kinda curious about the power difference between 3" and 2.75" as well. My road dyno numbers and my butt dyno both tell me that the 3" DP improved power across the entire rpm range under all driving conditions.
The stock hangers work fine if the exhaust is well designed. If the attachment points of an aftermarket exhaust don't line up well with the rubber hangers, I suggest bending the pickup points on the exhaust to make them fit better.
Old Mar 19, 2008 | 08:25 PM
  #269
SunKren's Avatar
I believe my Greddy TI and Megan's DP & TP are fully bolt on, so they would fit nicely with the original exhaust hangers.
Well, the curious kicks in when people says that aftermarket exhaust hangers kill rattles as exhaust gets louder and vibrates more due to loss of cat.conv.
Just want to double check with more people rather than to jump on the conclusion because some parts are just gimmicks for sale benefits?
Old Mar 31, 2008 | 08:07 AM
  #270
Mr. Furley's Avatar
Subscribe.
