EXO IX CAMS, Comparison questions
Old Aug 11, 2006 | 01:28 PM
Rnm's Avatar
Rnm
Originally Posted by sesso
an exhaust cam retarded 4 degrees with no tune dropped my 1/4 time .2 and raised my trap speed 3 mph so it does something...
that was untuned also runing 10:1 AFR just go get urself a nice 300$ exhaust cam from hks or something to tide u over till the IX cams come out. It will only be slighty lopey also. i ran these times with pump gas also at 24 psi. all i did was add some 15% nitro to my tank. it was 95 degrees at night also.
So tell me, were you running the same amount of boost before you added that exhaust cam?
Old Aug 11, 2006 | 02:10 PM
vwjeff's Avatar
Originally Posted by Axiom-Power
The Jun Evo IX is sporting 272s, and that's all the specs we have on them
as of today. We just talked to Jun and they are really close to bringing them
in. Once we recieve any more info we will notify you guys, and once we recieve
Them we will install and dyno test them ASAP.
OH PLEASE KEEP ME POSTED I want the 1st one you get in.... put me on the list... RIGHT NOW
Old Aug 11, 2006 | 02:18 PM
sesso's Avatar
yes it was the same or I wouldn't have anything to base my prior runs on.
Old Aug 11, 2006 | 05:52 PM
JohnBradley's Avatar
Okay so let me get this straight, you added Nitro as in Nitromethane to your gas? Nitromethane that doesnt mix with gasoline (petroleum) based fuels and even if it did that raises EGT's stratospherically? Nitromethane that is something like 110 bux a gallon? 15% of 14 gallons is 2.1 gallons.
You may have added methanol, but that is nowhere near the same. Next time dont post blatantly wrong information to support your power gain from a cam.
Old Aug 11, 2006 | 06:15 PM
sesso's Avatar
sorry I don't believe my info is wrong. even if I didn't run nitro that night have have greater pull at higher rpms. how do I know? I see it in my street racing . so quit trying to prove me wrong. I know how my car is and what it did before the cam. it is also my opinion if u don't like it look the other way. if u don't want cams don't get them. all u people do on this site is talk **** I swear. especially when there is a diff that I see
Old Aug 11, 2006 | 06:20 PM
boostedwrx's Avatar
HKS does have some coming out for the MIVEC heads. I read it in Turbo anyways... they didn't give a release date though.
Old Aug 11, 2006 | 08:45 PM
Warrtalon's Avatar
Wow...dainbramage at its best.
So, tell us more about this supposed "nitro" you use...
Old Aug 11, 2006 | 09:19 PM
sesso's Avatar
I guess u never owned a radio controll gas car? LOL ok MR stage 1 evo
im done with u guys ...
Old Aug 11, 2006 | 10:21 PM
Boost Freak's Avatar
Wow...
If you have steal parts in the engine the methanol in the fuel is a hygroscopic, Which means it easily attracts and absorbs moisture. The moisture could cause rust and corrosion on steel engine parts if the fuel is not removed. While it burns slowly, there is also the danger of explosion when nitro is used, Plus you have to flush the fuel system and motor after each use. And when you were talking to me about it, You wanted to run straight Nitromethane. It would be very dangerous to do and you don't want to mix it with pump gas. It is possible and it has been done successfully. However, there are a number of problems that make this impractical. These include the corrosive nature of the combustion gasses after Nitromethane is burned. This process produces large amounts of nitric acid, which is not only corrosive but toxic. And again to prevent serious corrosion, a thorough flushing of the fuel system and motor is necessary after use. There is Nitropropane, which can be mixed with gasoline. Nitropropane and gasoline have been tested and shown to provide small but significant power increases. And you can't put it in with your meth/water injection, as nitro does not mix with water. It is hard to believe you are running nitro in you fuel tank, and if you have ever heard of Nitro RC's you would know after each use you have to do some sort of after run maintenance(Flushing the engine).
Sorry to go off topic, Back on topic. The only cams I have heard are from Turbotrix. I think cosworth and GSC are coming out with some as well. Never heard of any other, But I am sure there are going to be some more.
Old Aug 12, 2006 | 04:10 PM
teknishnIX's Avatar
I too have only seen the cams from Turbotrix. Personally I don't see much advantage in changing the cams in the IX because of MIVEC. Thats the whole point of variable cam lift and timing is to have granny cams at idle and bigger lift at high rpm WOT. I'm sure there will eventually be some that will work with MIVEC to eak out a bit more power, but I just can't see it being anything tremendously significant. Especially for the price.
And Sesso.... I'd say you've inhaled too much of that Nitro.
Old Aug 13, 2006 | 07:53 AM
anjapower's Avatar
actually you've inhaled too much nitro because there's nothing variable about lift with MIVEC. It is only variable cam timing. You do not have dual cam profiles on the IX cams. Don't confuse VTEC with MIVEC.
Old Aug 13, 2006 | 07:57 AM
NoTec's Avatar
Glad someone pointed that out. Its amazing how many people dont know the difference between the two.
Old Aug 13, 2006 | 08:46 AM
teknishnIX's Avatar
Actually MIVEC is like VTEC and is both timing and lift. However, the MIVEC in the Evolution is limited to timing only.
Ultimately it would be nice to know why the IX isn't seening much gain from bigger cams.
Old Aug 13, 2006 | 08:54 AM
teknishnIX's Avatar
Yes, that was my bad. I didn't realize the Evo got a gimp version of MIVEC. I still love it though Big improvement over the VIII.
Old Aug 13, 2006 | 04:10 PM
anjapower's Avatar
word
Nissan2Evo
Apr 2, 2009 08:03 AM
EvoDom
12
Nov 19, 2008 04:03 PM
Late Apex
May 24, 2007 03:30 AM
mikiblueeyes
Feb 21, 2006 09:22 AM
dp2580
Automotosports - Illinois
Feb 6, 2006 04:15 PM
