Adjusting clutch. It adjusts PEDAL height ONLY?
Old Sep 11, 2006 | 08:38 PM
  #46
jmoudry's Avatar
Here's a dumb question but I gotta ask: How are you guys determining when the clutch engauges/disengauges? I understand that when you start to get grab it is engauging but how are making the measurement at that time? Is there a way to get these measurements while the car is parked? I can get a pretty good idea of when the clutch starts to disengauge by pushing on it with you hand and feel when the resistance increases but how can you tell when it fully disengauges?
Thanks
Old Sep 12, 2006 | 03:17 AM
  #47
smokedmustang's Avatar
Thanks
You mean for example, if the car starts to roll when the pedal is 3" off the floor, from THERE, when is the clutch fully engaged? ie another inch or so? from 3" to4" is the start and end of the clutch engagement? that is a good question, never thought about the END of the engagement, only the beginning. I don't know if that matters as much, but will wait to see what the people "in the know" say. I don't know. It is not a dumb question though.
Old Sep 12, 2006 | 04:44 AM
  #48
BlackEv03's Avatar
It's a stock clutch as far as I know. I just bought the car used, 62k on it now. I also just had it in to the dealer for the 60k service, so I wouldn't expect that there was any fluid problems, but they might have just topped off everything and called it good...So I need to adjust the clutch out first.
Old Sep 12, 2006 | 06:28 AM
  #49
That is alot of miles on the "stocker"!! Adjust it first. There is a rubber "plug" under the tranny, you can remove that, and look up there. if you See YELLOW, it is an ACT clutch, if you see annodized purple, it is an Exedy clutch up there. Have the dealership run your VIN, and maybe in the "history" it will say, if somewhere, your clutch was changed, and what it is.(it will even tell you what problems (if any) that car has had in the past.) If it is the stocker still, if adjusting it doesnt help, its time to put that "old" boy out to the pasture and get another one.
Old Sep 15, 2006 | 06:31 AM
  #50
jmoudry's Avatar
bumpfor detailed info on clutch adjustment.
Old Sep 20, 2006 | 05:24 PM
  #51
Thegame's Avatar
I need to give this a try. I'm still on the stocker at 19,000 miles. It never slips but it does feel kind of weak and it's very notchy even after BG synchoshift. Hopefully it will be warmer than 40 degrees here tomorrow!
Old Sep 20, 2006 | 05:30 PM
  #52
THe info and the links are all here. check the first few posts.
Kris86
Oct 5, 2016 10:31 AM
The_Police
Apr 6, 2016 07:05 PM
Go_Lancer_Go
Jan 19, 2010 09:46 PM
06MRV8Killer
May 17, 2008 01:30 AM
madmax4499
19
Nov 11, 2007 08:51 AM
