Is this BAD???
Old Apr 6, 2007 | 11:58 AM
jhanksevo's Avatar
Is this BAD???
Hey guys I have a friend and we did a lil dataloggin in his evo and he was getting 1 to 3 counts of knock at 7,000+ RPMs seemed like right before he was shifting gears just sparatic here and there and I was wondering if hes OK. I was told that u did not want any knock any the higher RPMs. Suggestions Please
Old Apr 6, 2007 | 12:11 PM
jhanksevo's Avatar
bump
Old Apr 6, 2007 | 12:35 PM
Stew's Avatar
Might have more luck in the tuning sections..
But, how sustained is the knock? Is it random? Does the car pull timing?
Old Apr 6, 2007 | 12:36 PM
oldscholevo's Avatar
i think you don't want knock on the lower rpm. you have knock on the higher rpm is because there is not enough fuel on the higher top. the fuel pressure is not high enough to supply the engine need. i think.
Old Apr 6, 2007 | 12:38 PM
Evo IX MR's Avatar
You do not want knock anywhere in the rev range. 1-3 isn't considered horribly bad but it also depends on other factors like what Stew said. What you want is 0 knock across the whole rev range.
4WS Tuning's Avatar
find the rpm's where the knock and most likely 6000+ from what your saying and take out a degree of timing if its pulling from those load cells.
Old Apr 6, 2007 | 04:44 PM
sonicnofadz's Avatar
1-3 counts of knock is what a lot of cars have from the factory. It is not enough to retard ignition timing (which causes loss of power). I would still try adding some fuel around that rpm range or maybe pulling the timing back a degree or two.
Old Apr 6, 2007 | 04:47 PM
SteelEvo's Avatar
1-3 counts of knock in the upper rev limit is not bad at all...stop putting out misinformation
SloEvo12
AEM EMS
15
Jan 1, 2012 09:48 AM
bumblebee04
Jun 27, 2011 11:44 AM
Nomad4g63
34
May 11, 2009 05:49 AM
Dapper Dan
Aug 29, 2006 11:21 AM
EVOONYOASS
AEM EMS
28
Apr 3, 2006 05:36 AM
