cosworth dyno on ix sean ivey
Old Apr 26, 2007 | 12:41 AM
  #46
evo ippo's Avatar
Originally Posted by Bosshog
Cosworth cams have proven to make power. We all know that cams on IX make less of a difference than 8, but they still make measurable difference that you can feel. Currently, there are no cams for the IX that add over 30whp over the entire curve on the stock turbo.
I got good gains on my car. Better example might be one of my friends car that was already making 417bhp before cosi cams with full boltons (Mani, TBE, O2, IC, IC piping, HKS RS, 680cc Inj). On 100RON pump gas, he made 20bhp more after cam install + tune.
What makes you say GSC cams are better?
i really don't think he is saying that GSC are better they just been more consistant in it gains from one car to the next but the cossie cams some make power some dont make that much but u see it all consistancy i want to know what i pay for and don't want it to be a surprise
Old Apr 26, 2007 | 01:56 AM
  #47
Bosshog's Avatar
I am sure that manufacturing tolerances of cosi cams have less variation than mappers who are unable to extract power from it or the power gains are 'blocked' by the wrong combination of parts causing a restriction. I personally haven't seen a thread where the customer was unable to extract some power from cosi cams - perhaps you would be kind enough to provide me a link...
I don't want to go off tangent here, but there are also many people who were not able to gain anything worthwhile from the FP evogreen turbo as well. Most likely, they do not have the necessary combination of parts and/or the right mapper to make it work. Just to give an example: I wrote to DB to see if I could gain from the 20G-LT. His response was that I had the minimum amount of parts he would recommend for a turbo upgrade and that he prefers a standalone before/with any turbo upgrade
Old Apr 26, 2007 | 06:40 AM
  #48
kouzman's Avatar
when i was referring to crappy 93 i meant that, that particular fill-up was bad from a Sunoco gas station... Stopped using that particular gas station and now i am using a brand new Shell with new pumps and everything. The car works much better...
Plus i have 5 gallons of torco racing fuel concentrate just to "correct" the octane in the gas even when i am running only 23psi on a daily basis...
Old Apr 26, 2007 | 09:24 AM
  #49
Piper's Avatar
Warrtalon:
Where are these weak dynographs and dissapointed customers that you've seen? I have not seen them. Admittedly, I spend much less time here than you and I may have missed some discussion on the Cosworth's. Also, I think that to expect an increase of 30hp/30tq (throughout the band) from cams is unrealistic, even on an Evo VIII. In the AMS thread about the GSC cams, they (AMS) said that the average gains for an Evo with the stock turbo with pump gas was 10-15hp.
Old Apr 26, 2007 | 09:28 AM
  #50
mudduck's Avatar
^^^ yeah, but the GSC S1's shine more in the midrange +23whp/26wtq, starting around 4200 and dying down back to stock fully by 6800, based off the same AMS test you're referring to...
Old Apr 26, 2007 | 09:39 AM
  #51
EvolutionBoy67's Avatar
Anyone try out the new Tomei pon cams? The pro cams should be coming out in June.
Old Apr 26, 2007 | 10:15 AM
  #52
BoOsTinGEVO190's Avatar
I think I just have bad combo with some parts That's all I dout cosworth are no doing anything I do believe they do make 10 15 whp and make tq you can see on the graph the hp stays up the exhaust part the reason I bought that is just because ti is to loud and no didn't pay 800 for the exhaust I bought the exhaust same price I sold the ti exhaust for I didn't want a loud exhaust nor did I want a stock one on sean said the exhaust might be holding you back a little probably like having a cat and my gas wasent all good either
Old Apr 26, 2007 | 10:29 AM
  #53
Piper's Avatar
What have cars with similar mods to yours made on that dyno?
Old Apr 26, 2007 | 10:48 AM
  #54
Dapper Dan's Avatar
sean ivey tuned my friends car and he was getting 8-10 counts of knock through the whole powerband......
Old Apr 26, 2007 | 11:00 AM
  #55
I'm going to change my intake to hks like sean said he was always happy with that intake
Add
gt spec manifold
ebay 02 housing
ams licp
Hopefully it would give me another
10-15 whp 10-15 tq
Ill be happy
Old Apr 26, 2007 | 11:05 AM
  #56
Yeah I had a little knock also
Old Apr 26, 2007 | 11:30 AM
  #57
kouzman's Avatar
Why knock though?
sometimes getting 1-2 knock counts while overboosting (spiking) it makes sense and probably it is not a real knock. With the torco i don't even see that even when i am having 24-25 psi spikes... absolutely 0 knock counts...
8-10 it is too much... Especially throughout the whole powerband, something must be wrong!
Does anyone remember in how many knockcounts the car is pulling 1 degree timing? i think its every 4...
i assume that at 10 knockcounts the car pulls 2-3 degrees timing, plus it goes to the low octane map...
2-3 degress of timing at the right places worth plenty of whp...
Personally anything over 2 knock counts is unacceptable...
Old Apr 26, 2007 | 11:41 AM
  #58
DynoFlash's Avatar
Originally Posted by Piper
Warttalon:
You said that the rest of his parts, including the Cosworth cams, were "not so good". Which, incidently, is the same as "no good". At least to me.
Who told you that they aren't so good?
If you only have three choices, and they are the best choice, then they can't be anything less than good, right? In fact, realitive to their competition, they are the very best cams that you can buy! I have the Cosworth cams on my car and they are most definately good. Better than good, even. I understand that they had some type of defect during one of their initial batches, but not anymore.
Piper - you seem to be filled with a lot of anger and negativity as of late - which is odd considering that Clay is a fellow Ex-Marine, I would suggest that you read what he has to say with a more open mind and he is a very dedicated and and informed Evo hobiest - anyway . . . .
In life all man made parts are filled with compromise, nothing man crafts has the perfection of a natural (god made) such as a sunset or a living being.
When he says "not so good" Clay means "COMPROMISED"
For example
The ideal exhaust on a turbo car is a direct 5" tube about 6 " long off the turbo angled in the direction of the car's air flow
As you make an exhaust that directs flow underneath the car and out the back and which also silences some of the sound you start to LOOSE SOME POWER
Generally, the quieter an exhuast the less power it will make
When Clay says "not so good" I believe he means "not optimal for peak power"
That does NOT mean that the exhuast will make NO power and / or is NO GOOD - it means that this customer may have selected an exhuast system which conatines some design features intended to lower the sound level which also may be effecting peak power production as well
As I have said - in life MAN MADE parts are always a series of compromises
To summarize - the design of automotive performance exhuasts involves the balancing of competing goals - power delivery and sound reduction - all manufactuers approach this science in their own manner. The power potential of a particular unit depends upon its design features which I have discussed at greant length elsehwere.
Old Apr 26, 2007 | 11:50 AM
  #59
DynoFlash's Avatar
You've heard _nothing_ but good about both the Cossie cams and apexi intake? I doubt that unless you just happen to miss all the comments. There's nothing special or good about the intake other than maybe its filtration, and the cams are a definite cause for debate. I don't even have a IX or pay attention to IXs that much, yet I've seen plenty of negative comments about the Cossie cams.
Anyway, the Hallman MBC and Walbro fuel pump are both staples of the Evo community that are known to work and work well. The rest of those mods are iffy.
What I don't understand is why the OP is admitting that he knows the Fujitsubo robs 10whp (and then someone else later claims 20whp, haha) when a cat-back only gives 10-15whp to begin with. Why would you spend $800 on a cat-back to gain no power just for the sake of being "quiet" when you could just leave the stock cat-back on there? Inquiring minds want to know...
Sadly, I think many customers purchase exhuasts based upon the recomendation of parts sellers who may have little or no tuning experience.
I think back to my formative days in the turbo import tuning world and often most of my purchases were made with little insight as to the relative benefits and advantages of different brands.
In many cases having a quiet exhuast is a great idea - e.g. if you live in a area where cops are handing out loud exhaust tickets, etc,
My point - is to inform the evo community that the design of an exhuast involves a balancing of features between sound, volume and power potential.
MORE attention should be given to the selection of the right exhuast
Sadly, most 19 year old parts sellers argue with me and say that "a 3" exhuast is a 3" exhuast"
if you keep buying your parts from those same 19 year old "experts" then continued medicorce power results on the dyno should be expected.
I have a suggestion - evo members - before you buy parts - call Sean, Myself or David Buschur, etc and ask US what to get
Just my two cents
Old Apr 26, 2007 | 11:57 AM
  #60
DynoFlash's Avatar
Your point is irrelevant without more data, does it constantly give 8 - 10 knock counts ? Was this on the dyno or road ? Has he recently changed fuels ?
A good tuner balances the tune with a given tank of gas to achieve a desired powre level and saftey level
If the car picks up a weaker tank of gas it can and should pick up some knock counts - this is how the ecu protects the engine and it goes a very effective job of doing so
If a tuner tuned a car for zero knock counts ever no matter which gas you get - the car would be very weak
The stock car can and does frequently exhibit knock counts all the time
The art in tuning is to feel the way to make the engine run very quiet and make more power with less knock counts, this takes experience and talent
