whats wrong with a 35r on pump
Old May 16, 2007 | 07:04 PM
  #31
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Originally Posted by enigmaDSM
i was talking about a roll....from a dig you still wouldnt have the advantage....
i'll try to post up a log if i can find one. 20psi at 4200ish.
stock block with 280s and some timing down low for that spool
If you're talking about 20 psi at 4200 rpm in 3rd gear, yours is the only 2.0 EVO able to do it (check the 35r spool up thread with all the logs). Also, you not gaining much, if any spool up from the timing. I've tested my 35r in a range of about 20 degrees of timing just to see how it reacts. The least timing spooled the turbo the fastest, but drivability was much worse.
Old May 16, 2007 | 07:28 PM
  #32
Cirrusly Evolvd's Avatar
I'm still trying to figure out where I said I had the advantage over a 35R? I only stated that I enjoy having spool lower in the RPM and that I didn't want to go bigger so I wasn't playing catch up with the stock IX's off the line.
So unless you have a point to make about something I said????
Old May 16, 2007 | 07:34 PM
  #33
MRadjahoe's Avatar
Originally Posted by fastassfourdoor
every one is badmouthing the 35r on pump gas and 2.0. I thought that u could get close to 450 on a dynojet. Can someone please explain this to me. I was interested in this turbo.
After having the 35r for almost a year. I dont think that there is NOTHING wrong with that turbo. Just have to be in the right gear@ the right time. I made almost 460 on pump with that turbo. full boost was seen around 4800rpms. On Race fuel the car is simply an ANIMAL. Thats all.
Old May 17, 2007 | 03:18 AM
  #34
Evo_7's Avatar
Getting my car tuned today....running about 2.0 to 2.4 bars...
The only bad part is that i wont be able to post my dyno since we do not have it here...
gstturbo
E85 / Ethanol
Dec 1, 2012 12:13 PM
aronjaskim
Jul 16, 2010 12:35 PM
EVOLV3D
64
May 14, 2009 07:31 PM
4drboost
E85 / Ethanol
Dec 6, 2008 04:08 PM
CA$H
57
Apr 30, 2008 11:30 AM
