My buschur racing pump gas evo
Old Jul 7, 2007 | 10:22 AM
  #211
Planet Evo's Avatar
Originally Posted by alpha;
If the intercooler is too small for the boost pressure / flow / compressor outlet temps. Sure. I have seen it first hand. ONCE. Seen it happen to someone else. ONCE. Again. If it's too small. Rarely happens though
Could it not happen say tuning a car from 8lbs to 30lbs. Car has been ran a lot with minimal cool down time. Intercooler is too small for the boost pressure / flow / compressor outlet temps. Quoting Tony Palo (T1). Though this might not be the case with Dave. I dont know. It's about the cross sectional area available for hot flow (height x depth). That's where pressure drop happens. I hate to use the straw analogy, but try to shove 85lbs/min of air though a straw. You can only fit so much efficiently, so you end up with more pressure at the inlet side than what makes it though the "ic" and you now have pressure drop. When you use an intercooler way past what it was designed for, it's not only the temperature increase, it's the pressure drop that you get. That's why it's always better to go taller and thicker on a core, not longer. You don't want to go too thick either, or you risk not getting enough air flow through the core, for cooling. This would explain the ait's being a little high and the pressure drop we were getting
Alpha, I think that we are talking about two completely different things. You are bringing up intercooling theory. Even though many points you make are quite textbook in nature, the post I was referencing has to do with terminology and accuracy.
If you reread what was typed, you will see that was was stated makes absolutely NO SENSE. Trust me and reread the sentence.
Old Jul 7, 2007 | 10:43 AM
  #212
kreionic's Avatar
I just dont understand why people can not believe this. First let me start out by saying I have 0 Buschur parts on my car. I have never purchased anything from them. Me for example. I am running about 26 psi on 93 octane on the stock ecu. Its all about the tune. I will gladly post logs of my car without my timing or AFRs. I have no knock at all. Just a random 1 in 1 or 2 spots but never the same spot in multiple logs.
Old Jul 7, 2007 | 11:02 AM
  #213
alpha's Avatar
Agreed. I should have (and will try before I leave) read through the whole thread instead of one page
Old Jul 7, 2007 | 11:20 AM
  #214
Planet Evo's Avatar
There is a big difference between, 26psi and say 400- 450HP and 525+ at 28psi on a GT35r and pump gas.
Its not always about boost pressure. Way too many things are being overlooked in this thread. Boost Pressure is a mere formality at this point.
Pump gas numbers of this sort actually are believable...its just that this is another thread about ONE specific car that magically can not detonate because it has BR all over it.
The amount of cylinder pressure needed to develop this kind of high rpm output is astounding for a 2.0l engine. My question is what RPM is this engine being revved to?
Old Jul 7, 2007 | 11:29 AM
  #215
kreionic's Avatar
Very true. I agree 100%.
Old Jul 7, 2007 | 11:45 AM
  #216
Darwinian's Avatar
Obviously this is an excellent car with a fantastic driver. Nice work.
Old Jul 7, 2007 | 11:52 AM
  #217
SIGSP2340's Avatar
Good job Trent, Dave and the rest of the Buschur team.
Old Jul 7, 2007 | 03:14 PM
  #218
Jasil's Avatar
Buschur has done this repeatedly not 525whp, but high 400's. You can sit here and scratch your head as to why other tuners don't put out those numbers regularly or you can concede that Buschur builds awesome cars and those awesome cars use primarily Buschur parts. I don't know what else to say you obviously don't like Buschur. It's in the details unfortunately.... I firmly believe that, but your right boost pressure is just a measure of resistance it's just a number.
Old Jul 8, 2007 | 07:52 AM
  #219
IHUNTV8's Avatar
i will post up the dyno sheet, in a bit. RPM was to 7500 when it made 525, and it was still climbing. I shift at 7800-8000 at the track.
Old Jul 8, 2007 | 09:08 AM
  #220
IHUNTV8's Avatar
Old Jul 8, 2007 | 09:26 AM
  #221
EVO8LTW's Avatar
Interesting torque curve. What are you using for boost control?
Old Jul 8, 2007 | 09:28 AM
  #222
IHUNTV8's Avatar
Buschur
Torque is over rated
Old Jul 8, 2007 | 12:49 PM
  #223
94AWDcoupe's Avatar
Originally Posted by IHUNTV8
Buschur
Yeah when you dont have it!
Old Jul 8, 2007 | 01:10 PM
  #224
SIGSP2340's Avatar
I am gonna take a guess and say he is using the AEM. I remember Dave saying that the AEM boost control holds pretty solid.
Trent, correct me if I am wrong.
Old Jul 8, 2007 | 01:30 PM
  #225
IHUNTV8's Avatar
Dont need it 135 mph in the quarter says it all....How much torque does your rig make?
