Full-Race Twinscroll 35R
Old Sep 1, 2007 | 10:32 AM
  #181
EV0lved's Avatar
Originally Posted by Max Power
There's ways around that!
My 3076 car is being street tuned this weekend to get base fueling and a few other things cleaned up and I'll be heading to the dyno soon. I'll keep everyone updated with logs and hopefully dyno slips soon.
trafficking coke works real well
Old Sep 1, 2007 | 05:23 PM
  #182
Geoff Raicer's Avatar
Originally Posted by scorke
I try Geoff.
I thought you might also be interested to see what borg warner is doing..
btw ALL borg warner turbos are twinscroll...
Old Sep 1, 2007 | 05:54 PM
  #183
AlwaysinBoost's Avatar
WTF is that electrical thingy on the compressor outlet???
Old Sep 1, 2007 | 07:28 PM
  #184
joeracer321's Avatar
It's the flux-capacitor. Once that baby reaches 88 MPH your going to see some serious sh*t.
Old Sep 1, 2007 | 07:34 PM
  #185
uglyevo's Avatar
like from back to the future?
Old Sep 1, 2007 | 07:45 PM
  #186
pbevo12's Avatar
lmao
Old Sep 1, 2007 | 08:42 PM
  #187
RSGuy's Avatar
ahahahahahahahaha i will never tire of that line
Old Sep 1, 2007 | 09:30 PM
  #188
A418t81's Avatar
Electronic diverter valve.
Old Sep 1, 2007 | 09:40 PM
  #189
Smogrunner's Avatar
Geoff et all,
I've seen several posts lately saying that long runners on exhaust manifolds are superior. Why is that?
Old Sep 1, 2007 | 11:00 PM
  #190
EvolutionBoy67's Avatar
Geoff are there any turbos by Borg Warner that are comparable to the gt35r and gt40r?
Old Sep 2, 2007 | 12:00 AM
  #191
scorke's Avatar
Originally Posted by Smogrunner
Geoff et all,
First is to use a manifold with sufficiently large internal volume that the exhaust output pulses of each cylinder are damped and a more or less constant pressure is available to the turbine. The internal volume of the manifold sufficient to obtain this pulse dampening can be 1.4 – 6 times the swept volume of the engine. That rules out pretty well all long runner exhaust manifolds, although a log-type one of the sort suggest by Allard may fit into the bottom end of this scale, and the current fashion in the US for mounting the turbo at the back of the car (in a car with a front engine!) would also conform to this approach.
The second approach is a pulse system, where the exhaust pulses provide additional short-term energy to the turbine. In a pulse-type manifold, Humphries suggests that the pipe runners should have a “cross-sectional area....not significantly greater than the geometric valve area at full lift [and] these connections should be kept short and free of sharp bends”.
He says the reflection of pulses within the system will be determined by pipe length, exhaust temperature and the status (ie open, closed or partially open) of the exhaust valves. In addition, at pipe junctions the exhaust pulses will split, with smaller magnitude exhaust pulses travelling down each pipe. “The overall pressure wave system that occurs in such a manifold will be very complex, with pulses propagating from each cylinder, pulse division at each junction, total or partial reflection at an exhaust valve...and reflection from the turbine.”
In order to take advantage of this pulse flow, “narrow pipes from several cylinders can be connected through a single branched manifold to one turbine....a four stroke engine which can have its cylinders grouped into threes is particularly attractive.” This is because “the opening periods of the exhaust valves follow successively every 240 degrees with very little overlap between them.... thus a sequence of pressure pulses arrives at the turbine...”
-jacked from a turbo performance book.
Ted also I feel that any restriction in the runner is energy that doesn't make it to the turbine. You need the manifold to be as big as possible before you start losing heat/velocity due to the pipe causing the gasses to cool off/slow down. I couldn't guess how you get the exact size, but I am almost positive thats why all the VERY FAST turbo cars usually use a long header.
Scorke
Old Sep 2, 2007 | 12:03 AM
  #192
scorke's Avatar
Not really, Borg's aftermarket devision isn't even really alive yet, they make some crazy stuff for porsche/diesel (kubota/ford f250/john deere) applications like the variable vane turbos, they have the technology just haven't decided the market is there......yet. Supposedly it might be in the works, my old roomate SoloEvo co-ops there...
Scorke
Old Sep 2, 2007 | 01:03 PM
  #193
That would be sick if we could get one of their turbos in a gt35r, gt37r or gt40r variation.
Old Sep 2, 2007 | 01:14 PM
  #194
scorke's Avatar
To be honest I am not sure how much sicker they would be than the Garret CHRA, the twin scroll housings are the only real advantage, if what Full-Race and others are doing I'd love to see TiAl making custom nice V band twin scroll housings.
Scorke
Old Sep 2, 2007 | 01:22 PM
  #195
Max Power's Avatar
Ditto... their stainless steel housings are very nice (and pretty light ) pieces. Would love to have a .9-1.1 AR twinscroll, t3 variant for a gt35.
