Full-Race Twinscroll 35R
Old Sep 2, 2007 | 01:26 PM
  #196
scorke's Avatar
Originally Posted by Max Power
Ditto... their stainless steel housings are very nice (and pretty light ) pieces. Would love to have a .9-1.1 AR twinscroll, t3 variant for a gt35.
Heck yes, maybe/hopefully bigger in A/R though
Scorke
Old Sep 2, 2007 | 01:33 PM
  #197
Max Power's Avatar
Bigger than a 1.1? You so crazy Scorke
Old Sep 2, 2007 | 01:37 PM
  #198
scorke's Avatar
On a twin scroll bigger=better unless it's insanely large.
Scorke
Old Sep 2, 2007 | 09:16 PM
  #199
Turbo Kyle's Avatar
Geoff owns all...LOL
Old Sep 2, 2007 | 11:38 PM
  #200
Geoff Raicer's Avatar
Sorry for the long wait, here is the 30R dyno plot, stock 4G63 with some small revolver 264s and our twinscroll kit. stock intake manifold, stock tb, stock headports, almost everything is stock on this setup
Originally Posted by EvolutionBoy67
Geoff are there any turbos by Borg Warner that are comparable to the gt35r and gt40r?
not yet, but they are working on them. They just released some turbos to compete with the 42R, i know the 35R and 40R are coming next.
That would be sick if we could get one of their turbos in a gt35r, gt37r or gt40r variation.
tell them!! they love hearing from enthusiasts.
Old Sep 2, 2007 | 11:44 PM
  #201
Ted B's Avatar
Originally Posted by Full-Race Geoff
Sorry for the long wait, here is the 30R dyno plot, stock 4G63 with some small revolver 264s and our twinscroll kit. stock intake manifold, stock tb, stock headports, almost everything is stock on this setup.
I take it this is a pump fuel chart?
Also, can you give a brief configuration sketch of the 600hp S14 you mention in your signature?
Old Sep 3, 2007 | 05:19 AM
  #202
NEUROEVO's Avatar
thanks for the 30R dyno plot. any way we could see the non twinscroll dyno plot for comparison? Is this the 3071 or 3076? what was your max boost? can't wait to see the rest of you testing on the bigger turbos with the necessary supporting mods to make the most of these turbos!
Old Sep 3, 2007 | 05:36 AM
  #203
CleverUserName's Avatar
happen to have a MIVEC equipped motor you plan on testing?
holy cow, i just noticed that graph has the stock TB on it. to clarify, that had the stock cat on it as well?
Old Sep 3, 2007 | 06:18 AM
  #204
BillAce's Avatar
The previous dyno was with a stock turbo + 10.5 hotside and O2 housing. That made a best of 338 with the same cam gear settings, both on 93 pump @ 22psi.
Ivey told me he couldn't believe the spool and I have to agree. The throttle response is amazing and the car just comes alive on part throttle. We didn't do a reace gas pull because I ahven't decided if I would use C16 or meth and didn't want to waste Sean's time.
So far the benefits are:
The car feels so responsive, a dyno just can't tell the story
much more midrange pull
a ton more top end, even on pump
The car sounds sick at idle, every stop light gets people looking.
It feels really different on decel, the engine braking is less than half of what it was with the stock turbo. (Geoff should include brake pads)
Makes much better use of the 5 speed gearing
Great DD or street car setup.
Old Sep 3, 2007 | 09:24 AM
  #205
Smogrunner's Avatar
Could whomever has the file, post up the gear ratio on that dyno pull? Was it done in third or fourth gear? Also, what kind/size of intercooler was on the car?
I'll post my observations after those questions are answered.
Old Sep 3, 2007 | 10:23 AM
  #206
mchuang's Avatar
I understand that this is your twinscroll kit Geoff, but the twinscroll turbo is not the only thing contributing to the spool here right? I would figure the back door piping which decreased overall lengths in charge pipes have quite a bit to do with it as well or maybe im wrong
Old Sep 3, 2007 | 11:01 AM
  #207
crcain's Avatar
Peak torque at 4800 rpm?
That sounds to me like your typical GT30 number.
Should we see any improvement on moving the power band down the rpm range with a twin scroll because based on that dyno I don't really see it.
Old Sep 3, 2007 | 11:06 AM
  #208
cij911's Avatar
Why are people so excited by this curve? Can't we achieve similar results with a stock 9 turbo + alk (a little less HP), but more tq from 3 - 5K?
Old Sep 3, 2007 | 11:07 AM
  #209
Smogrunner's Avatar
If this was a typical third gear pull on a dynojet with 94 degree temps, the spool-up is DEFINITELY, WAY faster than average. However, if it is a fourth gear pull, there is nothing here to brag about. Also, if the stock intercooler was used, it would enhance initial spool up but hinder peak numbers. The peak numbers here on 93 octane are not very impressive, but from the look of the graph, the tune is conservative and smooth. There may have been a lot of power left on the table. So, the jury is still out. We need more 411....
Old Sep 3, 2007 | 11:12 AM
  #210
Smogrunner's Avatar
First, this graph looks really conservative to me. Usually, with zero smoothing, you'd see a rougher graph on pump gas if it was tuned aggressively. I think there is more left on the table.
This kit would crush-destroy-humiliate a stock turboed 9. On race gas, this kit would make 500+whp, that is a hundred more than a 9 on race gas.
Edit: just saw you said "+alky." In that case, you are about right, but the top end of the 30R would still dominate a stock 9 turbo at higher rpms. Don't get me wrong, I love stock 9 turbos.
Anyway, without evidence/info of the gear used in that pull, we don't have the info we need to pass judgement.
