Full-Race Twinscroll 35R
Someone ask Sean Ivey of his impressions in driving the car. The dyno only shows one aspect.
Still, some questions I asked above will assist in putting this into proper perspective.
Would like to learn more on this, I also am curious about the 40R Twinscroll I read about in another post. But first things first, need some more overlay graphs on the 2.0 to see how good this thing really is.
twinscroll 30R
This was 3rd gear and is the safe tune I requested. This was the final pull before the car came off the dyno. Sean did a considerable amount of road tuning too. I noticed the same thing with the smoothing setting and knew that Sean really did tune for reliability. I don't see a reason to tune for numbers with C16 since I don't ever plan to use it. The car does feel great and meth is now really on my mind...E85 would be if I could get it reliably.
I have the FR vertical flow IC, pretty much their entire kit.
Thanks for the info billace & Shaun. Could you post your full list of mods just so we can get a better perspective of these results compared to other cars. Nice job by the way. Now we need to see of seat of the pants driving impressions can be put to objective testing/numbers. It may not matter as long as you enjoy the drive
Was this a .78 A/R T3 TS?
Revolvers, head studs, AEM Tru Boost, FR vertical IC, Buschur 3" exh, UICP, 3" air intake, 1000cc injectors, CBR COP setup, exedy HD Twin Disk.
I removed a Buschur Deluxe FMIC, downpipe, FR Prostock mani, 10.5 hotside w/ O2 housing. Before with that setup I was happy and didn't plan to change anything else because I wasn't willing to accept the negatives for more HP. Now, the throttle response is much better and power comes on and builds very linearly. It is smoother and much more enjoyable to drive. The sudden drop in speed after lifting off the throttle is decreased. There is noticeably less engine braking. The new setup feels better down low and is much better up top. From a guy that didn't want to change the stock turbo, this was definitely the way to go.
It could be that your COP set-up is causing less engine brake. That is what I noticed was happening when I was running my COP ignition on the stock ecu. Switched back to stock coils and back came the strong engine braking.
Sucka!! haha, again i was cheating with my 2.3, but again good for comparison, my 30R+2.3 vs a twinscroll 2.0
