Full-Race Twinscroll 35R
Old Aug 8, 2007 | 10:41 AM
  #106
evolved83's Avatar
man i would love to get a ride in your car when your are done tuning!
Old Aug 8, 2007 | 02:59 PM
  #107
EvoDan2004's Avatar
Originally Posted by scorke
Because the guy that started this thread was talking about a 35R while the guy you were talking to has a 3076....
my 3076 on my 2.3 would make full boost before 4k, so if this 2.0 is making it there than that is quite impressive.
Scorke
i hit today 23/24psi befor4k. if not dead on 4k.
i just put my custom dump tubes one. what a pita. big time. but a local guy felt bad for me and took me on board and helped me out.... now i can really beet this **** out of this thing.
i got 1 tweek from jestr today and it changed alot. so let me go do some logs and see where im at...
anyone can have a ride in the car. as long as you pay the 10 bucks gas is running me. hahaha. this car is drinking alot now. haha.
i will also be making a new thread with updates daily on ghow the car is doing and how the tune is going. if luck is on my side witch it normaly is not i should hit the dyno at cbrd saturday for a pump gas pull only. see u in my new thread and im very sorry for jacking the OT.
Old Aug 8, 2007 | 03:49 PM
  #108
xX v0oDo0 Xx's Avatar
DYNO, DYNO, DYNO, DYNO!!
Old Aug 8, 2007 | 03:54 PM
  #109
crcain's Avatar
Good luck with the car EvoDan!
Old Aug 8, 2007 | 05:31 PM
  #110
EvoDan2004's Avatar
thanks bro.
today i did a 4th gear log. i hit 24psi at 3950 rpm...... i start all my logs from 2500 2700. some where in there..... i am holding 22 23 psi at 7400 rpm. im going to home depot to get some toys for a boost leak test. then back to logging.
Old Aug 8, 2007 | 06:00 PM
  #111
Ted B's Avatar
What are the specifics of your present setup? What powertrain upgrades?
Old Aug 8, 2007 | 07:29 PM
  #112
Geoff Raicer's Avatar
some twinscroll 3076R pics
here are some pics of the 30R car we just finished up.
engine bay shot (40mm PWR evo 6 style radiator to give the upper hose more space)
side view (cardboard is on the MAF becuase we're waiting for a filter)
other side view
vertical flow goodness
ground clearance
this pic shows downpipe clearance and the Vertical flow charge pipe clearance. Plenty of space for the undertray and the cusco brace
two dumptubes
Old Aug 8, 2007 | 07:35 PM
  #113
Vigo's Avatar
Awesome.
Old Aug 8, 2007 | 08:18 PM
  #114
EvoDan2004's Avatar
like my mods??
full race 3076R twin scroll kit
revolver cams
supertech valve springs retainers
pro street cam gears -2in0ex
ported intake manifold
ported throttle body
forge mbc
forge rs bov
nisei upper icp
hyperflow fmic
custom lower icp
custom 4.0 intake
coil on plug .026 gap for now
3.5 down pipe back exhaust
exedy twin
walbro 255
1000cc RC injectors
perrin fuel rail
stock ecu
should be most of it ted...
Old Aug 8, 2007 | 08:58 PM
  #115
Whoop_ass's Avatar
thanks for the pics Geoff Looking damn good man!
good luck with your tuning Evodan, still impressive spool up.
care to take some logs of 2nd gear boost
Old Aug 9, 2007 | 03:33 AM
  #116
TR30's Avatar
to Full Race Geoff,
what kind of thermal barrier coating are you using on the manifold?
are you using weld els or tubing on the manifold?
Thanks!
Old Aug 9, 2007 | 04:49 AM
  #117
phenem's Avatar
Where did you get this radiator? Was there any modification needed to make this fit? Did the lower pipe fit perfect or did you have a make a pipe for that as well?
NICE WORK
~Zach
Old Aug 9, 2007 | 06:12 AM
  #118
Drifto's Avatar
Very nice looking kit for sure. I've been enjoying my twin scroll 3076 for roughly a year now and I'v really enjoyed it. It's nice to see other people using it. It's not a gimmick or buzz word. TS really works well.
Old Aug 9, 2007 | 06:30 AM
  #119
EvoDan2004's Avatar
ill do a 2nd gear pull today
Old Aug 9, 2007 | 07:06 AM
  #120
El.BlueEvo9's Avatar
30, hmmm, looks really nice.
