Green or 35R
Old Nov 6, 2007 | 09:55 AM
  #61
hks-evo's Avatar
35r
Old Nov 6, 2007 | 12:06 PM
  #62
crcain's Avatar
Originally Posted by ETS Tom
A 58mm will hit full boost in the very low 4000RPM range on a 2.0L and mid 3000s on a 2.3L like you were mentioning you might build. That turbo is capable of ~530whp at full tilt but is still a very good pump fuel performer. I run our T3 58mm kit on my personal car and couldn't be happier
Tom
When does a green reach 28 psi on a 2 litre generally? I sort of thought it was about 4k in 3rd gear. Am I wrong?
Old Nov 6, 2007 | 12:24 PM
  #63
SBR INC's Avatar
2.3l - 3076R - meth - dyno graph
My suggestion for an everyday 450 HP car - sorry the lines are hard to see - if you need a little more, 35R would fit the bill.
Mike Huml
Slowboy
Old Nov 6, 2007 | 02:02 PM
  #64
ETS Michael's Avatar
I can't speak from our experience on this one because we've not tested one, but I would imagine that it's in that ballpark or just a bit quicker based on its relatively small size and results I've seen from others.
Tom
Old Nov 6, 2007 | 02:13 PM
  #65
Freddy302's Avatar
On the dyno My green reached 28 psi @ 3500\3600
  #66
06ravenmr's Avatar
has anyone looked at the new 61mm turbo setup from booslogic. that is the setup i will be going with. as well as meth on the stock 2.0.
Old Nov 6, 2007 | 02:42 PM
  #67
03v8slayer's Avatar
I am going with the 58 trim from ETS Tom with a 2.3/meth. I think that will give me the power i want and the spool is great on them. Any one like that set up. Thanks ETS Tom and every one else for the comments and u will be hearing from me soon
Old Nov 6, 2007 | 02:56 PM
  #68
xiaoni420's Avatar
You have made a wise decision my friend
Old Nov 6, 2007 | 03:04 PM
  #69
gixxerman11's Avatar
my question is how are you at 316whp did you make that up
Old Nov 7, 2007 | 08:40 AM
  #70
03v8slayer's Avatar
No i did not make that up. Lest see here is my mod list. aem intake,fullexaust execept still stock cat. hallman mbc at 21psi, greddy camgears, buddyclub 272 cams,ported exaust manifold. And a tune by tunning tec. When i went on the dyno jet it put down 316whp. Why do u ask that? Its not hard to get our cars in the 300s. If i get a test pipe i should be close to 330whp. But i really want around 400-500whp that is why i am going with the 58 trim.
Old Nov 7, 2007 | 09:37 AM
  #71
mplspilot's Avatar
You are right. 4k it is.
TK40
Mar 8, 2010 11:58 PM
legal-z
Northeast Region
15
Mar 25, 2009 07:10 AM
evogottago
11
May 6, 2008 11:28 AM
turbodreamz21
Feb 10, 2008 03:45 PM
DS-03evo
32
Feb 17, 2007 09:09 PM
