!!ETS 61mm Tuned!!
Old Nov 11, 2007 | 02:20 AM
  #76
LT1runner's Avatar
Originally Posted by xiaoni420
I'm actually going to be injecting methanol with my setup so I will be fine with the 880's. I inject lots of methanol with two 1.0mm nozzles from Aquamist haha. I was running about 28psi on the stock turbo and wasn't even close to maximizing the duty cycle of the stock injectors, so I shouldn't have any issues running 30psi with the combination of the 880s and 2 x 1.0mm nozzles from Aquamist. I am going to stick to 30psi because I am still on the stock block. Once I build my block and want to run more boost pressure, I will look into bigger injectors if I have to.
The compressor on the turbo is .04mm smaller than that of the GT35R and, per Garrett's website, the turbine wheel diameter is 68mm, where the PT61 turbine is 70.1mm.
Wow I need to go to an aquamist setup. That's alot of meth. You ARE the meth junkie I may want to be someday
Old Nov 11, 2007 | 06:20 AM
  #77
SPEED's Avatar
Originally Posted by SickSilverNLow
I am running the 57 trim ETS turbo kit with all of the basic mods needed to run the car hard..... I love the spoolup on the 57 trim....its almost stock like and boost hits hard and the car just screams all the way to redline . I am getting a stroker and meth ordered here in a couple of weeks and it will be installed in the early spring so i am really considering to go with the 61 trim......GO BIG OR GO HOME.................
Let's not get crazy now..LOL. My 50trim doesn't even come close to stock like
Old Nov 11, 2007 | 06:51 AM
  #78
LIL EVOL's Avatar
Mine neither...definately some add lag...but well worth it.
Old Nov 11, 2007 | 06:53 AM
  #79
xiaoni420's Avatar
Old Nov 11, 2007 | 06:55 AM
  #80
electricevo's Avatar
Anyway of posting more speedo vids? Killer set-up i cant wait to get my ETS turbo kit!
Old Nov 11, 2007 | 06:58 AM
  #81
xiaoni420's Avatar
I'll try to work on getting some videos today, I can't promise anything, but I will let you guys know for sure.
Old Nov 11, 2007 | 07:33 AM
  #82
DS-03evo's Avatar
Looks nice!! what kind of boost are you getting in 1st and 2nd gear?
Old Nov 11, 2007 | 08:57 AM
  #83
SickSilverNLow's Avatar
geeet to work damn it.......... You have no excuse.
Old Nov 11, 2007 | 09:04 AM
  #84
xiaoni420's Avatar
I don't often boost in 1st so I couldn't tell you what I am hitting in that gear, but in second I'm hitting around 22-23psi.
I took some videos guys, give me a minute to post them up.
Old Nov 11, 2007 | 09:09 AM
  #85
xiaoni420's Avatar
Where are your videos!?!?
Old Nov 11, 2007 | 09:42 AM
  #86
xiaoni420's Avatar
Ok guys, I was able to come up with one more video. Videos don't really ever do cars much justice but I know you guys wanted to see another one. This is a 3rd-4th gear video on the highway, the camera car is going between 65 and 70mph. This will give you guys an idea of how well the larger turbos pull in 4th gear. Once again, this is only at 24psi and pump gas.
http://www.youtube.com/watch?v=o2by7jMS19s
Old Nov 11, 2007 | 10:00 AM
  #87
SlowCar's Avatar
ETS/DTM power
Old Nov 11, 2007 | 10:54 AM
  #88
hahaha.......its raining and and night the rain water on the ground turns into ice .......RT615s+Ice=Crash . I am seeing its gonna be nice in about a week. I will try to get some vids then.
Nice video man........
Old Nov 11, 2007 | 01:19 PM
  #89
xiaoni420's Avatar
Originally Posted by SlowCar
ETS/DTM power
You know it
You best be getting some videos soon!
Old Nov 12, 2007 | 02:42 PM
  #90
RSGuy's Avatar
dude, i love your car bro. So clean. That thing is hauling *** on pump gas!
