View Poll Results: Did Mitsubishi screw up on the clutch?
Yes, You screwed the pooch
483
61.69%
No, The clutch is fine.
300
38.31%
Voters: 783. You may not vote on this poll
Did Mitsu screw up on the clutch
Old Jan 20, 2005 | 07:47 PM
  #436
DsmAwdTurbo's Avatar
24k clutch chatters at idle hehe, dosnt slip or anything just the chatter is annoying
Old Jan 21, 2005 | 10:14 AM
  #437
feriosi'evotwin's Avatar
Originally Posted by TeenEVOwner
I have already had my clutch replaced by the warranty at 13,000 miles now i need another one at 25000 miles.... ...on the second clutch I didnt even launch it once!!! anyway now im forking over the money for a clutch now....not something I was wanting to replace at 25000 miles
i dont understand a clutch is a wear n tear part that warranty doesnt cover(like brake pads) ur transmission is cover by warranty. my clutch is outthere bad i only got 21,000 miles and my tranny went bad that was cover by the warranty im still waitin' for the dealer to handle my car with my new tranny its been a week n a half
Old Jan 21, 2005 | 05:04 PM
  #438
WoODStOcK's Avatar
MISTU NEEDS TO CHANGE THEIR FREAKING CLUTCHES!!!! how about we set up a petition for mitsu to get their act together and change the clutch. from what i hear, exedy makes the clutches for mistu.
Old Jan 21, 2005 | 05:11 PM
  #439
EVO8HKS's Avatar
9,000 mls and slight slipping.
Old Jan 21, 2005 | 05:12 PM
  #440
EVO8HKS's Avatar
also they should replace them w/ exedy twin disc.
Old Jan 21, 2005 | 05:23 PM
  #441
machron1's Avatar
I used to think it was a piece of crap because it would slip when I first got it. After that, it worked fine. I put about 50 drag launches on it, 4 track days, 4-5? autocrosses, and it lasted just over 30K miles. I did put a lot of highway miles on it too though. I think it's not a horrible clutch, but it's not a great clutch either. Also, when we are talking about the clutch I think it's really just the pressure plate that needs to be stronger. The ACT (Exedy) disk that went in there didn't look to be a whole lot different construction-wise than the one that came out.
Old Feb 9, 2005 | 07:26 PM
  #442
HoLeeRay's Avatar
it's an exedy and i agree. i'm only at 8.5k miles right now, but that's since november and i've done 30+ launches and i haven't run into a single problem yet. i did put in a SS clutchline, but i'm not sure if it would make that much of a difference.
Old Mar 11, 2005 | 04:25 AM
  #443
Deepseadiver's Avatar
2004 with 8,500 miles on it. It is slipping bad.
Old Apr 8, 2005 | 06:37 PM
  #444
MichaelB145's Avatar
I wonder if I'm the first person to put in their 3rd clutch into a EVO 8? 1st clutch lasted 1600 miles. Replaced it with a Mach V motorsports prototype. It was very aggressive and it lasted until 16,000 miles, but I was also much easier on this one. I finally put in a steal braided clutch line and a twin plate exedy clutch. We will see!
Old Apr 8, 2005 | 11:08 PM
  #445
LanEvoDemon's Avatar
22k and still holding well
Old Apr 8, 2005 | 11:25 PM
  #446
housedj's Avatar
Lightbulb
i believe the stock clutch is perfect for the STOCK application. it is made by Exedy if i recall, & yes it's the weakest link in the driveline. it seems that most people with clutches going out have:
1) modded their car
2) can't keep their foot out of it
3) do stupid things like 6k rpm & higher launches
4) dump the clutch like a RWD car
5) miss shifts primarily 1-2
my '03 has 10500 miles on it & doesn't APPEAR to be going out. not as crisp as new, but still works solid nonetheless.
Old Apr 9, 2005 | 08:38 AM
  #447
Dr. EV0's Avatar
19,000 miles on the clock and the clutch is toast. I don't race the car and rarely get it over 3-4k rpms. Now anything over 3k rpm's and the clutch will spin like crazy. I can't even pass a semi on the highway without it slippin'.
Old Apr 9, 2005 | 09:06 AM
  #448
1) modded their car
2) can't keep their foot out derof it
Wonder why the STI can drop the clutch without the clutch going out so quick? I don't think Mitsubishi dropped the clutch at 4K when they tested the car! Mitsubishi does not have any problem advertising the low 0-60 time or 1/4 mile time. Droping the clutch at 6k rpms is shaving at least a sec or more from their 1/4 mile time.
Old Apr 9, 2005 | 10:27 AM
  #449
Zeus's Avatar
My OE clutch was pulled at about 40k...
Old Apr 10, 2005 | 11:40 AM
  #450
MikeyM's Avatar
24,000 miles and not a hint of a problem. Lit bit of clutch chatter on cold mornings until everything warms up.
