Shifter very hard to move.
Old Feb 24, 2008 | 07:02 PM
Odenl0ki's Avatar
I searched through the threads and could not find any that had any good info on this issue. It started a few days ago when I had trouble getting the shifter to return to neutral. I figured that it was the cold weather. The shifter still will not return to neutral easily (left to right). The shifter itself is hard to move. I have not made any changes to the car. Any suggestions on what to look for and how to solve this?
Thanks in advance.
Old Feb 24, 2008 | 07:04 PM
BocaShula's Avatar
bump... i would like to see some replies on this
Old Feb 24, 2008 | 07:06 PM
mifesto's Avatar
this continues to happen even after the car is warmed up? try driving 10-15 miles.
do u have the stock shift bushings or is it brass?
Old Feb 24, 2008 | 07:10 PM
Odenl0ki's Avatar
It happens even after the car has warmed up and I think that the bushings are stock, but how and where would I check to make sure?
Old Feb 24, 2008 | 07:14 PM
mifesto's Avatar
already i am assuming you bought a used evo. do some self research and find out a "how to" on shift bushing in the engine bay. you will know right away if its standard rubber, polyurethane(usually green bushings) or brass.
Old Feb 24, 2008 | 07:23 PM
cush87's Avatar
bump.. I'm having the same problem. Just started a couple days ago. I have the stock bushing. I was thinking of changing the tranny fluid, as soon as the weather gets above freezing.
Old Feb 24, 2008 | 07:25 PM
EVOx2008's Avatar
I changed mine and its below freezing... shifting to 2nd gear is now difficult.. =( when the car is cold
Old Feb 25, 2008 | 12:56 AM
urslo4n8's Avatar
Always check the basics first, like the spring on the shifter base linkage that returns the shifter to the center postion. Maybe its worn or broken or out of place/alignment
Old Feb 26, 2008 | 03:02 PM
Odenl0ki's Avatar
I took the car to my mechanic and he found that it was the brass bushing that leads into the transmission that was seized up. He cleaned the bushing thoroughly, re-oiled it and its now working great!
2slowEVO8
Sep 19, 2021 02:14 PM
bbyevo8u
17
Apr 7, 2016 01:37 PM
rrkpitt15
16
Oct 13, 2012 03:55 PM
RejectedWolf
20
Oct 11, 2012 10:07 PM
HwangTKD
Jun 4, 2003 06:04 AM
