CBRD secret sauce turbo upgrade!
. This will be great to see the difference in power/torque from your current turbo, good luck mate. Are you getting the full banana or just the upgraded comp wheel version?Cheers Steve
similar, but the red had cams, our car didnt, our car had an upgraded, the red didnt lol!!
the red is going to be better over 29-30psi than ours.... as ours wasnt designed for boost levels over 30ish psi....
if you read through the thread, our goals were a potent 18-28psi pump gas turbo.... that is readily available.
cheers
cb
Thanks Chad, I mostly do AX & HPDE's so a pump gas tubro with sane boost levels is right up my alley.
is this a stock type reverse twin scroll turbo or does require another manifold?
also how about a price...
billet compressor wheel, and new turbine wheel...pm me for price
cb
