CBRD secret sauce turbo upgrade!
Old Sep 25, 2008 | 11:26 AM
  #541
kreionic's Avatar
double post
  #542
kreionic's Avatar
Originally Posted by mrdevo
Would you happen to have a dyno graph or can you offer roundabout numbers?
Chad just let me know if you want to me to post my before and after sheet with just the comp wheel for people. Its layed over my stock turbo run. Its the one with same boost, timing , and mivec maps. That was before all the part swaps. In that graph the only thing that changed was the comp wheel
Sorry guys i cant post it until chad gives the OK
Old Sep 25, 2008 | 12:19 PM
  #543
Cali2MDevo8's Avatar
Registered User
I wanna see your stock turbo run vs the full CBRD BBK turbo overlay
Old Sep 25, 2008 | 12:23 PM
  #544
phenem's Avatar
Old Sep 25, 2008 | 12:25 PM
  #545
CBRD's Avatar
of course charlie!!
thanks man
cb
Old Sep 25, 2008 | 12:26 PM
  #546
CBRD's Avatar
its pretty close, but charlie has a built head and cams...
caleb had him beat with the turbo, ,he added the head (lots of timing) and beat calebs car by about 4-5whp...
cb
Old Sep 25, 2008 | 12:30 PM
  #547
GootBoost's Avatar
let's see that sheet
  #548
theshadow's Avatar
bump for more dyno charts and little hints on pricing, options and availability
Old Sep 25, 2008 | 12:34 PM
  #549
Registered User
cb
I wanna see a Silver 8 with the CBRD BBK turbo on it, running 26-28psi
Old Sep 25, 2008 | 12:50 PM
  #550
kreionic's Avatar
of course charlie!!
thanks man
cb
OK here was the graph from my car. Only thing changed was the comp wheel. Same boost within .5psi, same timing, same mivec
Again this not the finished turbo just the comp wheel no turbine wheel
I can scan another graph tomorrow one with dotted lines for the second pull on that sheet if it helps out
Old Sep 25, 2008 | 12:59 PM
  #551
kreionic's Avatar
cb
Very true He does have a finished turbo though . I just need to get that turbine and then it will be easy to see if my car was a monday or friday built car
Old Sep 25, 2008 | 01:00 PM
  #552
EVO8LTW's Avatar
same wastegate actuator too?
  #553
kreionic's Avatar
Yes stock actuator. It will hold better boost with the turbine wheel in
Old Sep 25, 2008 | 01:01 PM
  #554
mrdevo's Avatar
Thanks, that's exactly what I was looking for.
Old Sep 25, 2008 | 01:05 PM
  #555
Evotech8's Avatar
Any info on the flow rating this turbo yet?
FP GREEN<BBK<FP RED?
