CBRD secret sauce turbo upgrade!
Old Sep 9, 2008 | 08:54 AM
  #391
CBRD's Avatar
Originally Posted by Turbojunkie
do you have the ability to test one on a full bolt on car running e85?
I do not have anyone local...
we could try it in kreionics car if we get some biggie injectors...
cb
Old Sep 9, 2008 | 08:56 AM
  #392
CBRD's Avatar
Originally Posted by Steveevo9
Chad,
That JM Fab exhaust mani looks absolutely stunning, I hope this works out well with your turbo. The craftsmanship is really outstanding, they do some nice gear alright.
Was Calebs car still fitted with the Perrin airfilter kit, that produced some nice power huh? Is the Perrin intercooler as efficient as the BR race intercooler Chad, as it looks very good as well? Pretty late here mate, I'll check back tomorrow.
Cheers Steve
Steve,
we really like the perrin intake, we are starting to use more... they require a retune in my opinion to see optimal gains... it did lean the car out a little because it was less of a flow restriction...
as far as the FMIC, I honestly feel the BR RACE is the best we've used... we have used the perrin before and it worked well... we have had probably EVERY fmic possible on cars here... including our own
cb
Old Sep 9, 2008 | 09:12 AM
  #393
Shacochis06's Avatar
test the jm ex mani for me
congrats numbers are only getting better cant wait to see the final turbo
Old Sep 9, 2008 | 11:47 AM
  #394
Chad is the turbo on calebs car still just the comp wheel or does it have the turbine on it now to??
Old Sep 9, 2008 | 12:18 PM
  #395
CBRD's Avatar
turbine and compressor...
jm fab exhaust mani will go on saturday and ill retune it.
kreionics car is going on the dyno shortly, with the compressor upgrade only, but with a JM fab intake mani and BR head.
cb
Old Sep 9, 2008 | 01:16 PM
  #396
blackdemon's Avatar
great numbers chad. cant wait to get my hands on this puppy. :-)
Old Sep 9, 2008 | 01:40 PM
  #397
EVO8LTW's Avatar
Are you planning to test at high boost? It would be useful to get a good comparison to other stock frame aftermarket turbos.
Old Sep 9, 2008 | 01:53 PM
  #398
Turbo Kyle's Avatar
Nice results...I guess the BBK is the name of the new turbo? Got any pics of the exhaust mani?
Old Sep 9, 2008 | 02:37 PM
  #399
bbk is the turbo name...i think bbk means billet blue kompressor
Old Sep 9, 2008 | 02:40 PM
  #400
Turbo Kyle's Avatar
Nice
Old Sep 9, 2008 | 02:47 PM
  #401
sspaladin28's Avatar
Damn, this waiting is killing me. Nice results though
Old Sep 9, 2008 | 05:05 PM
  #402
CleverUserName's Avatar
Originally Posted by CBRD
ok, im loading some charts...... i have sooo many...
the first two are of a STOCK turbo evo IX... vs. the BBK... similar boost (the BBK was up .3 psi sorry!!) .... similar mods..
car #1: BBK, 780s, Fuel Pump, Hallman Pro Rx, BR Fmic, Dc Sports Downpipe, Cobb Catback, Intake- 83 degrees 41% humidity
car #2: Stock IX turbo, fuel pump, hallman pro rx, ams fmic, dc sports downpipe, hks catback, intake- 68 degrees 36% humidity
at the same boost levels you can see we lose about 350rpm worth of spool up.... I did not put a boost plot because I wanted to get HP/TQ curves.... I can add that later.... there is an AFR plot for both, showing that they were tuned similar, car #2 was a little leaner.
once it hits peak torque, you can see the BBK has an advantage all the way to redline... I wish we had cams in this puppy...
here is that plot..
Here is the plot against a car with an HTA3076R, BR Race FMIC, COSSIE M3's, etc... EVO IX...
you can see an obvious spool up difference... is this a good comparison? well, for what we wanted yes... because we have lots of clients that ask about HTA's, our hybrid stage 3 50 trim, and stage 4 setups..... but everyone seems to run them on pump... so that was the point of this comparison....
Had our car had a set of S1's in it, i think we would see more torque and even more high rpm power.... NOW granted, the HTA is running at 1.3 psi less boost, I still dont think running it at 25.3 would have made up the difference AT ALL in the midrange... its just way too late...
here is that graph...
ill post some more data later, when I can.... with boost plots
but this is just FYI stuff for now... im very happy with what we have come up with... our clients have been waiting for us on this... and Im happy we are at this point.
cheers
cb
CBRD,
could you possibly post a FP Green vs the BBK that you have tuned?
Old Sep 9, 2008 | 05:47 PM
  #403
kreionic's Avatar
i am not chad but my car for sure. Race gas and I plan for mid 30s psi
And like we talked about today Chad we can gladly test the car on E85.
Old Sep 9, 2008 | 06:14 PM
  #404
DS-03evo's Avatar
Did you get that manifold on today?
Old Sep 9, 2008 | 06:22 PM
  #405
kreionic's Avatar
Dont want to clog this thread
post 63
https://www.evolutionm.net/forums/sh...73#post6098973
