Ams Evo Cam Test
Old May 20, 2008 | 03:08 PM
  #256
EvoDan2004's Avatar
Originally Posted by Colt4g63
Are we going to see JUN 272s?
i do not think so. i WISH. so bad
Old May 20, 2008 | 06:20 PM
  #257
JC evo1's Avatar
seems the Tomei Crane and S3 perform very close. If anyone wants an overlay of any of the cams i can post it.
Old May 20, 2008 | 09:22 PM
  #258
Colt4g63's Avatar
If no graph of the JUN 272s can we get some kind of idea on how they perform?? As in comparable to S2s, S3s, Tomei 280s?? I know they do very well from what I have been told.. and i know my car is VERY strong with them and making great #s even on stock ECU. But a graph would be OH so nice.
Old May 20, 2008 | 10:20 PM
  #259
Talonboost's Avatar
Yeah! How about the HKS 272, FP4R, and GSC S2.
Originally Posted by Martin@AMS
You have to be carefull with a stock turbo, too big of an exhaust cam with an early opening event will bleed off too much pressure on the combustion stroke.
Now THAT is interesting.
Gary
Old May 20, 2008 | 11:07 PM
  #260
JC evo1's Avatar
FP4R isnt posted on the first page yet.
but here is S2 vs HKS 272
Old May 21, 2008 | 05:29 AM
  #261
EVOlutionary's Avatar
Martin,
When the turbo is happy these tests are showing that choice in cam specs can make an absolutely huge difference, up to 100hp in some cases.
From your experience, will we see the same results when a turbo is pushed to it's absolute limit? For instance, you're running the boost controller wide open and it just won't make any more than XX psi up top. Can changing cams have much of an effect, or will the turbo itself still be the limiting factor?
Thanks for this test!
Old May 21, 2008 | 06:20 AM
  #262
Ted B's Avatar
The JUNs have the duration and ramp profile, but are a little down on lift as compared to the GSCs, Tomeis, and Cranes. The JUNs appear to be deliberately designed around the flow limitations of a stock head, and therefore are ideally suited for large turbo/stock head setups, although they would work well in any large turbo situation.
In short, a strong head with a milder cam works well. A large cam with a mild head is where one tends to run into issues.
What the cams are doing is improving the mechanical VE of the engine in the rpm ranges where you are seeing the big improvements. As the boost pressure is increased in those ranges, the power gap will continue to widen until the cams making the most power hit the limits of turbo efficiency.
If the turbo does not have enough reserve efficiency in those ranges to expose the limits of the smaller cams (much less the larger ones), the larger cams will be of limited benefit, especially when the tradeoff in spool characteristics are considered.
What the larger cams do is enable one to make more power, using less boost pressure. This becomes increasingly important as larger turbos with much high rpm reserve efficiency are considered.
Old May 21, 2008 | 01:13 PM
  #263
raf_EVO's Avatar
very useful post.
Old May 21, 2008 | 01:21 PM
  #264
Nez136's Avatar
I was having this conversation on sunday with Martin and he was saying the same thing, but I too would like to see how the JUN cams will work with the race head. I do also agree with the rest of your post as I am in a pickle when it comes to cam choice b/c everything changes as soon as I think about just doing a full race head instead of sticking with the stocker.
Old May 21, 2008 | 01:22 PM
  #265
Evolution IVGSR's Avatar
Cool I now know real results on most of the cams out there and my car will have a similar setup. Thanks AMS
Old May 21, 2008 | 07:53 PM
  #266
Talonboost's Avatar
This is what is supposed to be in Part 3, don't think the mag is on the stands yet:
Gary
Old May 21, 2008 | 08:17 PM
  #267
Nitrotiger's Avatar
great INFO
Old May 22, 2008 | 08:25 AM
  #268
Martin@AMS's Avatar
FP 4R's are up!
Old May 22, 2008 | 08:50 AM
  #269
Nez136's Avatar
Very nice, I can't wait to see the 5R's!
Old May 22, 2008 | 08:52 AM
  #270
navysandsquid's Avatar
AAHHH you skipped the Kelfords... sad face
