Ams Evo Cam Test
Old Jun 11, 2008 | 03:55 AM
  #436
CamMan's Avatar
[QUOTE=frenchy99;5761685]Are those the TX272? So I can go ahead and order them[/QUOTE
Thats them..
Old Jun 11, 2008 | 05:31 AM
  #437
evovin's Avatar
Originally Posted by CamMan
Depends on application, boost, fuel, porting etc. but we would generally use 280's
Why 280's? Is it better than 272's? Will I lose bottom end?
Old Jun 11, 2008 | 05:32 AM
  #438
Tribal's Avatar
Anyone ever heard anything good/bad about buddy club 272/272
Old Jun 11, 2008 | 11:45 AM
  #439
wshihdnevo's Avatar
You are best to upgrade.
Although the stock spring will not coil bind, it does not have enough valve control at raised boost and rpm levels, then if you miss a gear and buzz the engine, you have no safety margin.
Thank you Kevin, you have been very helpful.
Old Jun 11, 2008 | 02:28 PM
  #440
navysandsquid's Avatar
They are Awesome EVEN on a stock Turbo... as everyone and there brother is arguing about. Perfect loapy Idle. Very drivable, and strong! view SIG for Idle
Old Jun 11, 2008 | 02:48 PM
  #441
AutoMotoSports's Avatar
Thank you to Kevin from Kelford for coming in here and answering some questions. You have a great product and we were happy to test them
Eric
Old Jun 11, 2008 | 04:32 PM
  #442
wshihdnevo's Avatar
Not that I care too much, but Martin were you going to post the Greddy easy cams graph up? I know most people wont buy these cams, but I know its the only one missing from the others.
Old Jun 11, 2008 | 11:27 PM
  #443
Talonboost's Avatar
From the magazine: (this is from the August issue)
Old Jun 12, 2008 | 03:33 AM
  #444
JC evo1's Avatar
Do Kelford make GSC cams?
Old Jun 12, 2008 | 03:50 AM
  #445
GregGSC's Avatar
not that i know of... Some of the billets are the same but final grinding is not....
Old Jun 12, 2008 | 04:04 AM
  #446
coronaevo8's Avatar
Wow great job on the cams info iam sure every one is going to use it, just as much as me. Thanks
Old Jun 12, 2008 | 10:41 AM
  #447
bboypuertoroc's Avatar
Veteran: Army
Wow, those Kelfords are awesome.
Can I expect similar results on a IX?
Old Jun 12, 2008 | 11:07 AM
  #448
tvor's Avatar
Those Kelfords make me want to go broke buying more parts for my car. Damn you Martin!
Old Jun 12, 2008 | 11:39 AM
  #449
wshihdnevo's Avatar
^Exactly my thoughts...
Old Jun 12, 2008 | 11:54 AM
  #450
jbrown's Avatar
Am I the only one who can see that the GSC S2 performed just about the same as the Kelford 272? The GSC was a little stronger in the low-to-mid range, the Kelford had the edge up top.
Peak power is nice for dyno sheets and bench racing, but midrange power is nice when you have to shift and re-spool a turbo and actually win a race in real life.
I'm not saying to buy the GSC. Both cams responded very well on Martin's car. I have no loyalty to any of them, just calling attention to both sides of the coin.
