Ams Evo Cam Test
Old Jan 2, 2009 | 01:07 PM
  #541
jid2's Avatar
I think if you look at those graphs you'll see that the Kelfords and GSC S2 look basically the same. Any difference is within run-to-run variation for the most part. If you look at the cams themselves they are very similar as well.
I wouldn't expect any real difference going from S2's to Kelfords.
Old Jan 2, 2009 | 01:16 PM
  #542
KazzEvo8's Avatar
Originally Posted by DBallz
Well I need advice on cam choice for my evo 8. I'm currently running HKS 272's on a typical stock turbo setup. Well for this year I'm going with a FP Red turbo and some goodies to go with it. My power goal is 500whp on stock motor. So everyone on this forums say Kelford 272's are the way to go with a bigger turbo but I was leaning more towards to GSC S2's. I know I can get them both for a very good price and I know I have to upgrade my valve springs. But according to this original test the GSC were right behind the Kelford. I just want to make the right decision the first time.
Do both the GSC and Kelfords recommend/require valve springs or just the GSCs??
Old Jan 2, 2009 | 04:02 PM
  #543
jid2's Avatar
Both, specs are nearly identical on those cams.
Old Jan 2, 2009 | 04:37 PM
  #544
Evo H8's Avatar
+1 for the Kelfords. I have them with my FP Red and they made serious power on pump gas.
Looking at those two graphs, I see same power curve but the Kelfords make 20WHP more up top.
Old Jan 2, 2009 | 10:34 PM
  #545
monkey_187's Avatar
I just ordered my Kelford's, I cant wait to see the difference!
On the graphs the Kelford's did make more power.
Old Jan 3, 2009 | 03:22 PM
  #546
john.schuber's Avatar
I think the Kelford 272's and Kiggly Racing springs and retainers is the perfect setup for the red!
Old Jan 3, 2009 | 03:27 PM
  #547
Originally Posted by pure_evo
First off, I'd like to say that tests like this is what makes me appreciate the EVO community. Such extensive tests take time, effort, and not to mention dedication. To the crew of AMS (Martin specifically), I for one appreciate the hard work and it is going to serve as a valueable source for my next cam upgrade. Secondly, as I read through nearly 500 posts, I had to shake my head at the ungratefulness displayed by some evoM members with the repeated "what about this cam", "what about that cam" remarks. There are hundreds of cams on the market and the ones tested should give everyone in the EVO community an awesome baseline for choosing the correct cams for their own individual set up. It amazes me that the majority of people want everything at their disposal without doing a little research themselves. By reading through the several write-ups in "Turbo" magazine along with the knowledge contained in this thread, anyone should be able to make an informed decision as it relates to buying the proper camshaft combination. I personally learned quite a bit reading through this thread. I never would have taken into consideration the recommended threshold for a stock head (10.5mm lift) when comparing cams. From what I am able to gather, here is how I see things as it relates to my current/future set up. I plan on running a stock/E85 set up for the near term and ultimately go with a FP Red/E85 set up.
* upgrading from HKS 272 to HKS 280 gained around 20whp more with an increase of spool of about 150RPM
* GSC S2/S3 are recommended to be run with upgraded springs/retainers
* FP5R, GSC S3, Crane, and Tomei 280s are nearly the same overall
* GSC S2 and FP4R are nearly the same
* GSC S2 outperformed all tested cams (except Tomei 280s) between 5-7000RPM
* Kelford 272 has a 11.5mm lift
* JUN 272/272 = 225 intake and 226 exhaust; HKS 272/272 = 208 intake and 206 exhaust; GSC S2 = 217 intake and 217 exhaust
* JUN built around stock head flow rates
* BF272 (not tested) is nearly the same as JUN 272
* BC cams suck on stock head
* FP4R competed with Cosi M2 cams (not tested)
* FP4R has stock-like spool with better topend than HKS 272
So, with all of that said, as it relates to my current set and how I use my car (street, autox, drag), my choices would be:
1. GSC S2
2. Kelford 272
3. JUN 272
4. FP4R
I really appreciate the time and effort that the AMS crew put into these tests and it has certainly helped me to make my next cam upgrade decision.
"BF272 (not tested) is nearly the same as JUN 272" <----This is an old rumor that has been cleared up sometime ago.
Old Jan 3, 2009 | 04:36 PM
  #548
Evolved_6's Avatar
From looking at this thread I'm stuck between gsc s2's ( which have a bit more mid-range power) and the kelfords which make more up top. My current turbo setup is the hks gt3037s kit. Any one with some info on which route i should take? Car will be used for street/TA/drag.
Old Jan 3, 2009 | 08:11 PM
  #549
awdturbo8's Avatar
i like the TOMEI 280 on my 37R.was running the GSC 280 .the old version
Old Jan 3, 2009 | 08:14 PM
  #550
ray3328's Avatar
Let us know what kind of gains you see after the tune.
Old Jan 4, 2009 | 12:56 PM
  #551
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
I have no idea if the Kelford require springs but I figure it has almost identical lift so comman sense says yea put springs in. I don't plan on reving the motor more then the stock redline but I don't want issues with the build later.
Old Jan 4, 2009 | 01:00 PM
  #552
scorke's Avatar
Much more than max lift to worry about with valve springs.
Ramp Profile, duration....The distance the valve moves is sometimes irrelevant if the rate at which it opens/closes due to the aggressiveness of of the cam lobe very very fast.
Scorke
Old Jan 4, 2009 | 01:17 PM
  #553
Ted B's Avatar
A top tier cam cannot deliver full power potential with the weak factory springs unable to exert accurate valve control in the meat of the powerband. It makes about as much sense as spending on a full-tilt suspension but using small wheels and skinny tires.
Old Jan 4, 2009 | 10:32 PM
  #554
Wheatley's Avatar
Do you guys think the FP beehive springs would be enough for the kelfods?
Old Jan 4, 2009 | 10:50 PM
  #555
monkey_187's Avatar
I will let everyone know how they do, Im also installing a gt35r with it so I should see some really good gains. I have to leave Iraq first.........
