Ams Evo Cam Test
Old Feb 25, 2010 | 11:52 AM
  #661
blkVII's Avatar
As far as I know the Cosworth 272s are a very similar grind to a Kelford 272 but just cost more They make very similar power from all that I've seen
Old Feb 25, 2010 | 12:13 PM
  #662
srajeremy's Avatar
thanks ive heard the same...
Old Feb 25, 2010 | 03:08 PM
  #663
E85evo8's Avatar
I would say that the newest GSC S2 cams will make the most power vs. any other 272* cam. I would even swap out my brand new Kelford 272 cams for a set of GSC S2's...IMO
Old Feb 25, 2010 | 03:18 PM
  #664
n2oiroc's Avatar
if you had 280's i would trade you for my new s2's.
Old Feb 25, 2010 | 03:25 PM
  #665
E85evo8's Avatar
I initially bought a brand new set of Kelford 280's but they never went in my car...I didn't want to trade any spool or low/midrange for a few more ponies up top, but I do like the new GSC S2's over the Kelford 272's...IMO
Old Feb 25, 2010 | 03:28 PM
  #666
n2oiroc's Avatar
i want to soften the torque a little to prevent parts breakage, ill be running a 4088r on a 2.2!
Old Feb 25, 2010 | 05:31 PM
  #667
E85evo8's Avatar
If you make power you won't be able to avoid parts breakage....unless you are a very talented driver. I will know first hand this season how my tranny, axles, and transfer case hold up to my 600+whp and 500+wtq running on slicks
Old Mar 10, 2010 | 08:42 PM
  #668
Midnightevo8's Avatar
I have the HKS 272's, both Exhaust and Intake on my 05 VIII and it doesnt lope. Not that it's a big deal and I hear that lope is associated with bad tune. When I start the car and the engine is cold it will lope very nice until it warms up and then it idles right at about 900-1000 rpm and it doesnt lope anymore. How would you like make it lope all the time at idle?
Old Mar 12, 2010 | 01:59 AM
  #669
anyone?
Old Mar 29, 2010 | 08:33 AM
  #670
jrohner's Avatar
Very interesting read (even though I don't have an Evo). Thanks AMS.
Old Mar 29, 2010 | 10:34 AM
  #671
drb's Avatar
drb
Lope isn't necessarily associated with a bad tune. Some of the bigger cams are going to lope regardless of how good the tune is. A good tuner can usually help keep the car from stalling at an idle despite the lope.
Old May 10, 2010 | 09:49 PM
  #672
Blowstock06's Avatar
awesome thread *thumbsup*
Old Jul 6, 2010 | 07:26 AM
  #673
Kakihara's Avatar
I'm not sure what I say is right,
but I think that the loping is (also) related to the rpms at which your idle is set, if your tuner rises your idle to 1000rpm you will have less lope than if it goes down to 790-800.
I have GSC S1 that "kinda" lope when my idle goes really low (for some reason I sometimes get 790rpms)
Old Jul 6, 2010 | 08:43 AM
  #674
evo8john's Avatar
Mine used to lope before the tune but now it runs smooth as stock. Idle was completely unchanged. I am running hks 272's...
Old Jul 12, 2010 | 11:26 AM
  #675
EvoGuy5's Avatar
Def going Kelfords. Thanks for the info...and the parts.
