9sec9/OKIX's EVO, ROUND TWO!
Old Jul 8, 2008 | 06:01 AM
  #316
David Buschur's Avatar
I'd prefer if we as a team leave the "coulda-woulda-shoulda's" for the other guys.
Making 530 whp on a stock appearing turbo on our dyno here in ANY weather condition is freaking flat out amazing. I honestly don't think we ever need to go down that "coulda" road.
Old Jul 8, 2008 | 06:02 AM
  #317
LilRico's Avatar
Originally Posted by 9sec9
Do it Reuben, You're a daisy if you don't.
I've already started in getting this thing going on my car, just waiting for a phone call.
Old Jul 8, 2008 | 07:19 AM
  #318
Mellon Racing's Avatar
Originally Posted by davidbuschur
Stock size valves are what 9sec9 wanted used in this head when we originally did it for him. Since we only needed to do a quick valve job to freshen it up for the new engine we left them.
9sec9, I'm curious why you chose the stock valve sizes then and went with them again...I figure you've got a theory behind that choice at least. I placed an order for a BR stage 3 head recently and I'm always open to suggestion.
Old Jul 8, 2008 | 07:24 AM
  #319
fmly evo's Avatar
so when do you think your gonna get a run on that thing to get a time???? good luck to all on breaking into the 9's...
9sec9 will you be at the shootout with this beast?
STevo
Old Jul 8, 2008 | 07:33 AM
  #320
JohnBradley's Avatar
Remember some of your flow rate calculations include the power regained by the electric water pump. It hasnt been dyno'd specifically by itself but its in the neighborhood of 10-15whp most likely.
Old Jul 8, 2008 | 07:41 AM
  #321
GrocMax's Avatar
That's why he was estimated at 12 HP per lb/min minus dyno loss instead of 10 to 11- oxygenated fuel, drivetrain work, and other items that show gains on a chassis dyno vs. an engine dyno.
Old Jul 8, 2008 | 07:42 AM
  #322
wreckleford's Avatar
Originally Posted by CO_VR4
Just for the sake of accuracy, the Evo Red is NOT similar to the Subaru Red, except in color designation. They are completely different turbos and spin in reverse one from the other. The Subaru version is rated at 65 lbs/minute; the Evo version at 56 or 60 lbs/minute, depending on who you ask.
The Green has never been the White Rabbit. The White Rabbit used a stock turbine wheel and the Green compressor wheel, while the Green has a proprietary larger FP turbine wheel and the larger 5 bladed FP compressor wheel. The Green also has not "become" the White -- the Green has stayed the same, while the new WhiteHTA has a 47 lb/minute HTA compressor wheel, coupled with the stock IX turbine wheel.
Al's been away from stock appearing turbos for so long he just can't remember
I'm a bit confused... the White Rabbit uses a Green compressor wheel and the Green uses something else? Why is the White Rabbit wheel called a Green wheel if the Green doesn't use it?
Old Jul 8, 2008 | 07:46 AM
  #323
scheides's Avatar
EvoM Moderator
At this power level, almost certainly. Still, this turbo looks like a strong performer!
David, any chance you could post some dyno plots of the turbo on trent's car, along with some specifics? Pretty please?
Old Jul 8, 2008 | 07:53 AM
  #324
"White Rabbit" is not the same as the new "White" why in the world they chose that name is beyond me...let the chaos continue
Old Jul 8, 2008 | 07:56 AM
  #325
BR Race FMIC and coolant temps
Since there has been some posting lately of FMIC air temps and how a particular product works, I thought it would be good to post a log from the car yesterday.
We were dealing with very hot/humid conditions. The datalog screen shot I am going to post is the final run on the car after 3 consecutive runs, all done in 23 minutes. We had one small squirrel cage fan on the car.
I have highlighted the peak boost and the air temp/water temp/mph etc at that point for reference.
Here's the screen shot with further explaination below it.
Starting RPM 2508
Starting Air temp 100.4
Starting coolant temp 156.2
Starting vehicle speed 28.85
Starting boost .23
Peak boost 38.88
Ending RPM 8355
Ending Air temp 104
Ending coolant temp 158
Ending vehicle speed 96.20
Ending boost 26.88
Overview, Coolant temp with NO engine fan running only rose 1.8 degrees.
Air temp with one small fan only rose 3.6 degrees.
The air temp sensor is located in the upper i/c pipe about 10" before the inlet to the throttle body.
The radiator is a super impressive part too. Indy is actually going to be working on making our small radiator kit in this same design. This should allow for a radiator half the size of stock with cooling capabilities much greater than the stock radiator. When the new radiator is finished I will offer the radiator and electric pump as a DIY kit that bolts into the car.
Good information and good reference with me providing an actual screen shot.
  #326
9sec9's Avatar
Chris, the decision was actually not quite so calculated as some of the others. The head was in excellent condition, other than the exhaust valves leaking due to some unknown buildup on the seats. A real quick light touchup and they were good to go. I have a fully built stage 3 motor with stage 3 head and everything also sitting here. It has larger valves in it, but we decided to keep it in one piece and just go with what we had. I also still think that the stock valves are fine for up to 65 lb turbo's, give or take a little. Just my hunch, nothing very scientific.
Old Jul 8, 2008 | 08:10 AM
  #327
GrocMax's Avatar
Intake Valve = (( RPM * CID ) / ( # of Cylinders * Avg port velocity * 282.7433388 )) ^.5
then convert to equivalent area/2 for a 4 valve
Old Jul 8, 2008 | 08:15 AM
  #328
gotcha, thanks for the feedback.
on another note, I bought the green a long time ago and was disappointed in the minor pump gas power gains (I rarely ever run race gas). I suspect the red will make a more significant difference with that larger turbine.
I constantly get asked by customers for my thoughts on the green vs 35r since I've had both and it would be nice to have a turbo that fell in the middle as far as pump gas power that bolts right on.
Old Jul 8, 2008 | 09:03 AM
  #329
itzwolf's Avatar
I've really been thinking about picking up your Race FMIC, would I need any special piping configurations to mate it with an AMS 37r turbo kit? This information pushes my desire for it even more.
Consider me sold on this, you release it I AM buying this. Would AN lines be an option? I know I would need my theromstat housing welded to attach an AN fitting.
Old Jul 8, 2008 | 09:21 AM
  #330
ace_2822's Avatar
What about the fp4rs?
