Forced Performance Evo Red Turbo data
Old Jul 14, 2008 | 03:30 PM
  #421
9sec9's Avatar
jb, I think DB said his was in 4th also. That's why I mentioned in an earlier post that our RED would be one of the SLOWEST spooling RED's, mainly because of the modifications we made to the manifold. Trent's spoolup and ours appears to cross each other at 4500 RPMS. If that holds true, for our purposes, we actually gave up nothing to gain the topend of the manifold. Indy and I were talking a few minutes ago about the new V0 and it could really be a great street combo with the Red, provided it improves the low end/high velocity area and gives more uptop too. Can't wait to see it get tested myself.
Old Jul 14, 2008 | 05:12 PM
  #422
David Buschur's Avatar
The Red has already gone 10's on pump gas, Trent ran 10.7 at 129 last week.
I was thinking the V1 would be the best intake manifold for the Red actually. I don't think you'd lose much low end at all but still gain a bunch up top.
Old Jul 14, 2008 | 05:22 PM
  #423
Mellon Racing's Avatar
Originally Posted by 9sec9
If I recall correctly, we dyno'd our GREEN setup before the Stage 3 build (w/stage 3 head) and after using the HKS 272's. Actual gain was either 11 whp or 18 whp. That was head being the only 'performance' mod change. The engine was built, but no horsepower in just rods/pistons unless their lighter.
it's probably worth mentioning that you don't have the standard BR stage 3 valve sizes..so there might be a difference.
Old Jul 14, 2008 | 05:29 PM
  #424
03whitegsr's Avatar
Originally Posted by SpoolnupTuning
Its already been posted that the wheel is the same as the 3076 turbo runs and even said that its really rated over 60lb per min. This turbo with race gas or E-85 and ported will go 10's. That is on a rightly modded car and not some everyday car.
How is it a 3076 when the 3076 and the Red spin opposite directions?
"Do we look like the two dumbest guys in the world to you?"
Old Jul 14, 2008 | 05:30 PM
  #425
gamebred26's Avatar
I thought it was 93 and 110 mixed? It was straight 93?
just trying to get the facts.
Old Jul 14, 2008 | 05:35 PM
  #426
dsmfan95's Avatar
Not trying to be a wise *** so don't get pissy...I know you guys are sensitive..just trying to get the facts.
It's sad I have to write that disclaimer but that is what these threads have come to.
He ran 10.9 @ 125 on straight pump. The 10.7 @ 129 was on a 93/110 mix, but still not really tuned.
Old Jul 14, 2008 | 05:38 PM
  #427
gamebred26's Avatar
Ok roger that thanks...
Old Jul 14, 2008 | 05:53 PM
  #428
IHUNTV8's Avatar
Yes went 10.97 on straight 93 with a boost leak, i fixed the boost leak and half *** retuned the car thats why i threw a couple gallons of 110 in the tank. Im no tuner and figured it was good insurance
Old Jul 14, 2008 | 05:56 PM
  #429
9sec9's Avatar
Good point Chris. Since we're still using stock size valves, our velocity might be up a bit more than a standard Stage 3 motor. We have a fully built Stage 3 motor sitting at Buschur Racing right now. It has the std Buschur Stage 3 head with larger valves. That's our backup, unless one of the 'crew' needs it asap.
Old Jul 14, 2008 | 06:01 PM
  #430
9sec9's Avatar
Originally Posted by IHUNTV8
... Im no tuner and figured it was good insurance
Trent, "THEN FIND A TUNER". Isn't there a good tuner anywhere in OHIO?
You can't have mine, he's taken.
Old Jul 14, 2008 | 06:04 PM
  #431
IHUNTV8's Avatar
We can share buddy
Old Jul 14, 2008 | 06:11 PM
  #432
warp9's Avatar
I think I want to move to Ohio......But I will need to get a job, maybe I can start a corn crop!
Back on the subject of the RED, I am planning on putting my order in as soon as my funds says "go". I am on a stock IX turbo and a BR stage IV so it should be interesting to see how it does..
Old Jul 14, 2008 | 07:45 PM
  #433
I'll buy it
Old Jul 14, 2008 | 07:56 PM
  #434
4kinboost's Avatar
I've done this in the past when testing out new strategy or cranking up on boost to 'lay someone down'.. I've gotten better results from mixing it up with an unleaded blend.
If you don't mind me asking, What was the 60ft time on that pass?
Old Jul 14, 2008 | 08:02 PM
  #435
PsychDr. HN$'s Avatar
Im assuming that the RED is internally gated. Is the RED offered in an externally gated configuration? If so, are there any advantages to be gained if it is externally gated?
