FPwhite + Evo 9 + 91oct
Old Jul 11, 2008 | 12:24 PM
  #136
BGevoIX's Avatar
Originally Posted by Phalse
Does anyone else find that amusing?
As I was once told by FP after having a problem.. because it couldnt possibly be their product, oh no, it HAD to be me
"did you check your downpipe for a shoprag? Anything that could possibly be blocking the exhaust flow"
While not word per word, as I dont have the direct quote, and while I'm not sure who said it.. yes, fp blamed the lacking performance of their product on a possible shop rag stuffed in my downpipe. This was a FP bolt up 50 trim for the DSM, somewhere around 02/03, and was spooling late 5k due to what FP later admitted to an improperly assembled turbo.
Still damned amusing.
The you would be pleased to know that I was asked if I hat a cat conv. on mine because if it melted it might be causing the issues.
Old Jul 11, 2008 | 12:27 PM
  #137
BGevoIX's Avatar
Originally Posted by ForcedPerformance
Doesn't it flow a few more lb/min of air from 6krpm on out to redline? Isn't that what the turbo was supposed to deliver? To me looking at that data, the White model turbo outflows the EVO9 from 6krpm and above without giving up any spool up on the bottom end.
Why the car isnt making any extra power with the extra airflow is a good question. I think everyone glossed right past the data again.
BOOST ON!
Robert Young
Yeah...it flows like 2 lb/min more above 6k rpm...that's it. Considering I was told it has a 47lb/min wheel, and the stock 9 turbo is rated a little under 40lb/min, I would expect a little more air flow from peak to redline. From the testing my tuner (Razorlab) has done, this turbo is NOT worth the money for your standard day-to-day customer. But you know...the only thing we can do is...
BOOST ON!
Old Jul 11, 2008 | 12:33 PM
  #138
denny424's Avatar
LOL I like that you have a sense of humor after spending a good amount of money on the turbo and tuning! Keep your head up and like they say.... BOOST ON!
Old Jul 11, 2008 | 12:36 PM
  #139
BGevoIX's Avatar
Originally Posted by EvoTio
Well after reading all of these new posts, how does the owner of the Evo who was tuned on the White feel about his car now? How does it drive after his recent tune? I would like to hear his feedback.
My feedback is that it doesn't really feel much different than the stock turbo. Still a nice clean pull, but I am disappointed. Walking in to get the tune, I told Razorlab I would be happy if the car would just make some minor gains throughout the powerband because I knew the intake temps would be a few degrees warmer. After the 91 tune, I was a little disappointed. We took a break to let it cool down and dropped the 100 octane in. On our break, we both were thinking the turbo would probably wake up once we surpassed 25-26psi...but no luck there either.
  #140
evoPirate's Avatar
You could save some bucks by purchasing a used 9 turbo for lets say 400, and send it in for 600$ so you're still saving 300$ and you've got no down time, then sell your stocker once the white is on for 400$ and your back to the 600$ or less if you get more for your stocker. I have a ix turbo arriving tuesday, iim still confident this turbo has god results in it, just gotta play around with it, plus it'll give people some bolt on + e85 numbers
Old Jul 11, 2008 | 12:44 PM
  #141
Phalse's Avatar
BGevoIX,
Sorry that you had to be the test mule. On behalf of the rest of us cheap bastards, may i say thank you sir, for throwing yourself on the grenade and saving us!
Any plans to put the IX stocker back on ?
Old Jul 11, 2008 | 12:45 PM
  #142
RazorLab's Avatar
Originally Posted by EE
Now that many members mentioned it, the real question is:
why is the fp white producing less power with more airflow??
on 91 octane, the fp white flew more air all the way from 2500 up until 7200, why didn't it make more power under 5500 rpm??
Look at the boost plots for 91, you will see the FPwhite is running a tad more boost at 3700 rpm to 5000rpm, then about the same boost from 5500 to 6400 or so, then more boost from 6500 or so up. Now look at the airflow chart and those areas that the FPwhite was running more boost, walla! it's running more airflow.
The FPwhite does show more power up top on 91, why it doesn't show it down low I'm not really sure and I was wondering the same thing while on the dyno. It was warmer that day by about 12-15F intake temps over the span of the pulls, which I mentioned earlier in this thread.
Moreover, why did the test stopped at 7200?? the stock rev limitter is at 7600, and most people will take it up to 8000!
area under the curve is what matters most. Accordingly, taking the test to 8000 rpm would show a considerable advantage for the white over the stock 9 turbo, bcs when you go flat out you remain within 6300-8000 rpm. Airflow is there to prove the white can be as good as the 9 turbo at low/mid range.
Both 91 and 100 where already showing a down turn in power well before 7200, if you are looking for that "lost power" for the 400-600 rpm between 7200 and 7800 or whatever, that isn't on the dyno charts, then I'm sorry it's not being shown.
Originally Posted by EJ207RA
Utlizing the same tuning parameters for two turbo's with differing cfm potentials makes no sense to me.
As I have said a couple times already, it was to show a true A to B comparison. I've also already stated I did other tuning as well, with not much difference.
On 91 octane, the boost levels and timing are already close to max, especially on a customers car.
Now I am starting to understand why Buschur gets so flusterd in threads like this. The general questions are fine but some of these posts are just amazing. The car has bad compression and a bent valve now? Someone that looks at motec datalogs all day doesn't understand when I say a 12-15F spread? Why wasn't a stock frame turbo revved out an extra 400rpm? Good lord.
Old Jul 11, 2008 | 12:48 PM
  #143
Mr. Evo IX's Avatar
rgds
Yea that's a good question.
I'll take a stab as to what it could be. Just because you customize a OEM turbo to flow more air than a IX turbo doesnt necessarily mean it is doing so efficiently.. right? The white could just be blowing hotter air, and then your airflow would not equal HP.
* edit removed reference to VIII, I didnt realize the white is based on a IX frame, the previous rumor was that it was a VIII frame.
Also, is there the possiblity that this particular turbo has a problem? It sounds like Byran and his customer contacted FP, What did FP suggest?
And of course that the car developed a problem between tests or has a boost leak.
Old Jul 11, 2008 | 12:53 PM
  #144
BGevoIX's Avatar
Originally Posted by Vapor
this is so typical of EVOm posters... ONE test and the whole thing is a "flop"
I think the data is encouraging for one and I look forward to more test results before I spend my hard earned bucks.
Agreed. The thing thats hard to digest is spending almost $1400 of HARD EARNED money and losing midrange and picking up 10 or so at 7k. If I had money to throw away, it wouldn't be a big deal, but I don't.
Old Jul 11, 2008 | 01:05 PM
  #145
BGevoIX's Avatar
Originally Posted by Nuked
BgevoIX - Thank you for allowing to post your results up here. Could you give any impressions on how it feels on the street compared to the stocker? Like throttle response, lag between shifts etc?
Thanks man
SQ
Throttle response, lag time (or lack of) and the way the car feels when stretched out to 7200 or so feels no different than the 9 turbo. With the current results of the car, I honestly feel that I paid $1400 to have a cool little plate on my turbo that says EvoWhite.
Old Jul 11, 2008 | 01:07 PM
  #146
BGevoIX's Avatar
BGevoIX,
If I hadn't sold it to fund this turbo, YES...it would already be back on. As you can see, I do have a thread with the EvoWhite turbo for sale if anyone is interested...LOL
Old Jul 11, 2008 | 01:11 PM
  #147
BGevoIX's Avatar
Haha...at least we can laugh...although its tough to know you spent that much money for these results. Thanks for posting all the airflow, load, boost, and hp/tq curve charts up. Razorlab tuning FTMFW!
Old Jul 11, 2008 | 01:12 PM
  #148
denny424's Avatar
Hey you should have waited on posting the results a day and got someone to buy the great white hype! BOOST ON!
  #149
mplspilot's Avatar
So the compressor is rated higher, big deal.
The turbine is all the same old IX wheel, as far as i understand, so to get more flow out of the HTA68 wheel, you need to push that turbine farther and while you may be doing that, you're increasing the backpressure and definitely temps.
So maybe you can flow a tad more, but it comes at the expense of higher backpressure and higher temps. The car already has an good core IC, so you can't really improve either of those. So there's no more power.
I think this was somewhat to be expected, considering FP just reused the wheels originally destined for HTA Green, basically gambling that it would work mated with a IX turbine. Instead of just throwing them away. Well it didnt work..
I just hope a RED isnt a fiasco like this. Obviously that group of boys touting each other's achievements in their sigs wouldn't tell you that..
So Bryan, thanks for posting up the info!!
Old Jul 11, 2008 | 01:14 PM
  #150
BGevoIX's Avatar
I'll take a stab as to what it could be. Just because you customize a VIII turbo to flow more air than a IX turbo doesnt necessarily mean it is doing so efficiently.. right? The white could just be blowing hotter air, and then your airflow would not equal HP.
Car is running great and boost leak test was conducted the night prior with no leaks. FP suggest me send them all the datalogs to see if they could help find the "20-30whp I'm missing" from the tuning...which kind of points fingers if you ask me. But again, I'm just the guy who spent $1400 for the gains (or lack of) provided.
