False knock, stock ecu, built motor
Old Oct 18, 2008 | 12:28 AM
  #46
haseeb's Avatar
im facing false knock in my car .my mod r in my signature ...
but i use to see high knock only when im launching and when i hit rev limit ...
but i think its because of the vibration in my car and power fc reading high knock due to vibration ...
cud be wrong also ...
Old Oct 18, 2008 | 12:37 AM
  #47
Erik@MIL.SPEC's Avatar
At some point I would love to see the build sheets on the engines/cars with built motors that experience false knock and the ones that don't. I wonder if any patterns would show up.
Old Oct 18, 2008 | 05:00 AM
  #48
DimitrisIX's Avatar
good point erik
Old Oct 18, 2008 | 05:02 AM
  #49
CBRD's Avatar
we have had this issue before on 2.3 motors..... even with balance shafts and fluiddampers...
my take comes down to tolerances in the bottom end on assembly....
we have had to tune cars over 3200rpm on the dyno and do what we thought was "right" for timing from 1800-3000 rpm where they would peg the sensor at 36....
hopefully the ecuflash patch will allow some adjustment... aem is an expensive alternative.
cb
Old Oct 18, 2008 | 05:33 AM
  #50
Mellon Racing's Avatar
mine had this problem on the stock shorty...It began when I put the header on and it makes a nasty sound at 3500, a cast manifold would solve it I suspect.
Old Oct 18, 2008 | 08:07 AM
  #51
jid2's Avatar
I know all my clearances on my 2.3L and I'll be up against this pretty soon. Fingers crossed for no-knocky.
Piston-to-wall: .0020- .0025"
Crank/Rod/Mains: .002"
Old Oct 18, 2008 | 08:08 AM
  #52
DimitrisIX's Avatar
so this is probably an issue only up to 3500 rpms. false knock cannot happen above that?
Old Oct 18, 2008 | 08:10 AM
  #53
I'm hesitant to say that's always the case but I've tune quite a few of these cars and only a few exhibited true false knock that couldn't be quelled with less timing, more fuel or higher octane
Live4Redline
Jul 17, 2024 07:09 AM
Nomad4g63
34
May 11, 2009 05:49 AM
ecuflasher
Aug 1, 2008 11:48 AM
RedLanEVO
98
Jul 13, 2008 04:48 PM
jcsbanks
May 12, 2008 11:12 AM
