Cant get into any gear
Old Oct 24, 2008 | 04:17 PM
def1's Avatar
Hi everybody.
Well I just finished running some logs on the car and doing some third gear pulls and when it was done it was kinda hard to get into first. I stopped the car for about 15 minutes and when I got back in all the gears would not want to go in. After a while I could get into first and once Im moving it shifts great but if Im completely stopped then its hard to get into every gear. 2nd, 3rd and 5th are not hard to get into but 1st is very hard and 4th is impossible. I havent tried reverse yet. I dont know what it is because when Im driving it goes into gears perfect. Also I havent launched it in weeks and its only been launched 4 times. Any ideas?
Old Oct 24, 2008 | 04:35 PM
Evo9tunerz's Avatar
What clutch do you have?
Old Oct 24, 2008 | 04:36 PM
def1's Avatar
i dunno. bought it used. i wanna say act tho cuz i dont think it is stock but i cant really say
Old Oct 24, 2008 | 04:37 PM
diiirk@AwdMotorsports's Avatar
check the linkage maybe
Old Oct 25, 2008 | 12:25 AM
4WS Tuning's Avatar
bleed your clutch line with better fluid, sounds like youre heating up the fluid so the clutch isnt completely disengaging which makes it basically grind into gear.
Also you should change your tranny and diff fluids since you bought it used and most likely dont know the last time they were changed, alot of people neglect maintenance when they plan on selling a car.
Cheers!
Old Oct 25, 2008 | 12:53 AM
huevosrancheros's Avatar
did you recently adjust the clutch???
Old Oct 25, 2008 | 03:10 AM
EvoLutionized8's Avatar
check linkages under hood (shifter bushings) and definitely +100 ^^ (4WS tuning)... Had a similar problem and one of the bushings cracked and was mashed... Fluids throughout due to used vehicle purchase... and wouldn't synchro's be possible since you can only get into gear while moving??? GL..
Old Oct 25, 2008 | 10:52 AM
def1's Avatar
Ok well the problem is gone. As I would step on the clutch it felt really short so i took a closer look and the clutch was still engaged halfway so i pulled it all the way up and it fixed the problem. Any ideas why it would have been stuck halfway engaged?
Ive been driving around with it for a bit and the problem has not reoccured so Im just wondering what would have caused it
Old Oct 25, 2008 | 10:53 AM
def1's Avatar
Cheers!
that is actually the first thing i did do when i bought the car.
Old Oct 26, 2008 | 12:13 PM
def1's Avatar
anybody?
im thinking my slave master cylinder is goin bad? i dont know why else it would be getting stuck halfway engaged
Old Oct 26, 2008 | 12:26 PM
Clutchdc5's Avatar
i think i may have the same prob, im gonna try to change tranny and diff fluid, see how that works out, when im coming to a stop, around 5mph , shift into 1st gear, even though it should go in smooth
Old Oct 26, 2008 | 01:18 PM
iy's Avatar
iy
Hard to get into first gear? Double clutch it No joke it goes in smoooooth. Just put it in neutral, release clutch, blip gas, pull in clutch and put into gear. No problems!
freshevo8
May 7, 2010 05:38 PM
m0nkie
12
May 2, 2010 06:03 PM
bluej20
11
Dec 18, 2007 09:46 PM
Ralli04
May 7, 2007 05:29 PM
dan628
Mar 2, 2006 06:58 AM
