help severe knockout
Old Oct 28, 2008 | 06:25 PM
Malik_EvoIX's Avatar
so my car has a built trans and a fidanza clutch and redline fluids, i took it out for a spirited run today and it grinds in 3rd (sometimes) and when going into 5th gear at 7500rpm it grinds so bad and wont even go into 5th its a lockout or whatever. i am so pissed spent so much $$$ on trans rebuild 3,000 miles ago and now it is grinding? help and suggestions thanks.
Old Oct 28, 2008 | 06:28 PM
gsrboi80's Avatar
You can try adjusting the clutch rod out a little see if that helps
Old Oct 28, 2008 | 06:29 PM
we will see the clutch pedal is close to the floorboard. bump
Old Oct 28, 2008 | 06:31 PM
gsrboi80's Avatar
I bet the adjustment is def your issue then
Old Oct 28, 2008 | 06:52 PM
my clutch is the fidanza 2.1 with a resurfaced flywheel...where can i get the specs for the adjustment?...more out or more in?
Old Oct 28, 2008 | 07:00 PM
BlackIX's Avatar
http://www.youtube.com/watch?v=vYJxQyjIhUw
Old Oct 28, 2008 | 07:23 PM
Sales@ACT's Avatar
In reading this I thought it odd that you wrote the following recently " i have the 2.1 (shop didnt have 3.2 when i needed it badly) over iam impressed with Fidanza no lock out's, my ACT had horrible knockouts"
In this thread https://www.evolutionm.net/forums/sh...53#post6264753
Wrote this in another "i lost in alot of races because of the ACT MB7-HDSS (high RPM knockout) switched to a new fidanza doesnt happen no more"
In this thread https://www.evolutionm.net/forums/sh...72#post6264672
FWIW as the others on this thread have said your problem can most likely be fixed with an adjustment.
The only time an adjustment won't fix it is if the parts are warped from too much heat and if their is insufficient airgap to allow the pressure plate to release the disc (which is want causes lock out). It makes no sense that the clutch would work fine and then all of a sudden lock you out of gears.
If you follow the procedure in that video you should be fine.....unless the clutch was overheated to the point that no amount of adjustment will fix it. Good luck.
Old Oct 28, 2008 | 07:57 PM
it recently started happening the first 1k after my trans build everything was fine. car is launches only 3-4 times a month.
Old Oct 29, 2008 | 04:24 PM
moved the clutch pedal up and noticed no more grinding in 3rd and checked clutch drag, it's not as notchy as before.
Old Oct 29, 2008 | 04:41 PM
akauf's Avatar
I think that ACT was just trying to say that their clutch would most likely have worked fine if it were adjusted properly.(if it wasn't). My ACT is notchy into second and third but no lockout. I'm going to adjust it and possibly replace the rubber line / pill with a SS piece. GL with the clutch.
rupp003
33
Aug 29, 2013 10:26 AM
evodac
16
Sep 21, 2012 02:59 PM
strtrcng426
96
Feb 29, 2012 08:53 PM
pb91
Jun 8, 2011 02:44 PM
SleepySamurai13
15
Apr 29, 2009 12:53 AM
